2006 NISSAN TITAN ELECTRICAL SYSTEM
Recall Date: 11/30/2006
Summary:
ON CERTAIN CREW CAB TRUCKS, THE WIRES IN THE HARNESS WERE ROUTED THROUGH THE REAR DOORS AND INTO THE BODY. THESE WIRES MAY BREAK DUE TO OVER BENDING OF THE HARNESS AS THE DOOR IS OPENED AND CLOSED. THE HARNESS CONTAINS WIRES FOR THE DRIVER SEAT BELT PRETENSIONER AND FOR THE FRONT PASSENGER SEAT BELT WHICH IS PART OF THE OCCUPANT CLASSIFICATION SYSTEM. WIRES FOR THE REAR AUDIO SPEAKERS ARE ALSO CONTAINED N THE HARNESS.
Consequence:
IF THE WIRES FOR THE SEAT BELTS AND SPEAKER WIRES BREAK AND MAKE CONTACT, THERE IS A POSSIBILITY THAT THE PRETENSIONER MAY DEPLOY. IF THIS HAPPENS WHEN THE SEAT BELT IS RETRACTED, IT WILL NOT BE POSSIBLE TO USE THE SEAT BELT. IF ONE OF THE WIRES ON THE RIGHT SIDE HARNESS FOR THE SEAT BELT TENSION SENSOR BREAKS, THE PASSENGER SIDE FRONT AIR BAG WILL NOT DEPLOY AS DESIGNED IN A FRONTAL COLLISION INCREASING THE RISK OF A CRASH AND PERSONAL INJURY.
Remedy:
DEALERS WILL REPLACE THE WIRE HARNESS COVER WITH A DIFFERENT TYPE THAT PREVENTS OVER BENDING OF THE HARNESS AND THE HARNESS WILL BE REROUTED FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON OR ABOUT FEBRUARY 19, 2007. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Potential Units Affected: 96500
Notes: NISSAN TITAN
2006 SE, CC, Big Tow, white
Born 5/06
Nice to see they are on top of these issues. I hope no one has been hurt by having a failure due to this. Who could have opened and closed the doors enough for this to happen? I'd think it would take years of movement.
Clint
You have two choices in life:
Pretty much the same info from the NHTSA web site:
Make : NISSAN Model : TITAN Year : 2006
Manufacturer : NISSAN NORTH AMERICA, INC.
NHTSA CAMPAIGN ID Number : 06V459000 Recall Date : NOV 22, 2006
Component: ELECTRICAL SYSTEM
Potential Number Of Units Affected : 96500
Summary:
Consequence:
Remedy:
Notes:
CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONS VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Born 5/06
Interesting. Nothing at nissanhelp.com yet. I didn't even know that we had a seat belt pretensioner that needed to "deploy". I thought the seat belt tension thing was completely mechanical in nature, and not electrically actuated. I hope I didn't mess this stuff up yanking 12 gauge wire through the door boots. I wonder what the fix is, going back to the part from prior year?
FYI...The 2004 F-150 now has 80 factory TSB's....just checked.
"Oh the Titan has too many TSB's..."
Yeah, right...
PRG Performance Kit w/SAW's
Born 9/2004
Seat belts are passive/aggressive, which means you can move it manually, but in an accident, it''ll cinch up tight to your body. When you release it after an accident, it must be replaced, as once cinched up, it can no longer be used.
