Old 01-05-2007, 05:17 PM   #1 (permalink)
Electrical question
I'm installing a Painless Performance dual battery control system on my truck. I'm supposed to tap into a power source that is hot in the run AND start position ONLY. Has to be powered in both run and start and NOT when the ignition is in the off position.
Any of you electrical guru's out there happen to know the location of a wire under the dash that is of this type? I'd prefer drivers side as this is where I'll mount the switch but passenger side would work as well. I can just run an extension cable.
There is no power requirements for this wire as it only goes to the switch. All the real power goes through the solenoid and batteries. I have 2/0 welding cable for that.
Any help would be appreciated.
Regards,
John
05 LE CC 4X4 - Red Alert w/every factory option
American Racing Chrome Chambers 17X9 Rims
Offroad/Big Tow
Damello Offroad Custom Rock Sliders
Retrax rolling bed cover
Bed Extender
Rancho 4" lift w/ PRG Traction Bars
Fox Coilovers & Total Chaos Upper A Arms & Deaver Leaf Spring Upgrade Pack
1", Billet block in rear w/Bilstiens
Defender Roof Rack w/6 offroad lights
Mile Marker Winch mount brush guard with Warn 9500 Ti winch
Bushwacker fender flares (black)
John Harden is offline   Reply With Quote
Old 01-06-2007, 06:04 PM   #2 (permalink)
Re: Electrical question
In fuse panel next to glove compartment, just do a Add-A-Circuit fuse tap to the first 15A fuse on left side of this fuse block. That fuse is the switched (passenger side) power outlet. You can easily run the wire under the dash, between console and firewall to the driver side for a switch connection.
BHMTitan is offline   Reply With Quote
Old 01-06-2007, 06:20 PM   #3 (permalink)
Perfect.
Thanks!!!!!
Offroad/Big Tow
Bed Extender
Old 01-06-2007, 07:21 PM   #4 (permalink)
No problem. I'm about to do this for some auxillary reverse lights. I've got a question for you... where/how to get +12V power under the hood? I'm using a relay, found the trigger I need for the relay, but still need to determine the best way to get the power. Ideas?
Old 01-06-2007, 07:27 PM   #5 (permalink)
"where/how to get +12V power under the hood?"
Is this a trick question? How about the + battery terminal? If you still have the OEM battery, I think there is an accessory terminal.
Old 01-06-2007, 07:30 PM   #6 (permalink)
Where did you put the second battery?
Old 01-06-2007, 07:32 PM   #7 (permalink)
Yeah, got the OEM battery, but didn't notice an accessory terminal. Not sure what that is, assuming it'd be a place to easily add connections. Didn't see any. Was wanting something a little cleaner looking that just sticking the wire under the positive terminal screw / bracket.
Had a idea to mount the relay in the small fuse box behind the battery, but still need to power wire connection from somewhere.
Old 01-06-2007, 07:36 PM   #8 (permalink)
If you look under the plastic cover on the + battery terminal, there is a screw terminal where you can put a ring terminal, IIRC.
I have an Optima which has a separate terminal also, but it is getting cluttered. I just bought a 7 circuit relay activated Cirkit Boss from Painless to make things a little neater.
Old 01-06-2007, 10:44 PM   #9 (permalink)
Sorry, gonna show my ignorance again. What's a ring terminal? Both my positive and negative connections are cluttered up with different wires all going to them.
What's a good way to clean this all up?
Offroad/Big Tow
Bed Extender
Old 01-09-2007, 12:44 PM   #10 (permalink)
There are a couple of ways to clean things up. You can use a relay controlled device to provide additional circuits on the + battery terminal. Painless makes some called Cirkit Boss that provide 7 additional circuits. They can all be on & off with the ignition, or they have a different model with some ignition switched and some always hot. You need to make sure that the fuse ratings of the additional circuits are adequate for your purposes.
Another way to go is by using distribution blocks, fused for the positive and unfused for the negative. A heavy gauge wire goes to the block from the battery, and then smaller gauge wires to your various circuits. Car audio places on the net have them. They also make a bunch of them for use on boats. Obviously, wire gauge and fuses need to be selected in accordance with the loads of your various circuits.
HELP - Electrical Grounding Question John Harden Titan General Discussion 5 12-24-2006 11:22 AM
Electrical question for trailer power fiveyoungs Titan Towing & Hauling 3 09-07-2006 06:23 PM
Car electrical type question moore101 Titan Interior Discussion 2 03-23-2005 03:49 PM
Electrical Question Earthdog Titan Interior Discussion 0 11-14-2004 02:22 PM
Door electrical question? newenglandtitan Titan General Discussion 0 03-31-2004 09:45 AM
