Old 01-10-2007, 08:52 AM   #1 (permalink)
Boomer135's Avatar
Vehicle Dynamic Control (VDC)
I know what the whole VDC deal is, but my question is when I turn it off and stomp on it, I can somtimes see the "slip" light on the dash flash while just giving the truck throttle and no brake. why does it still slip when the VDC is turned off?
Boomer135 is offline   Reply With Quote
Old 01-10-2007, 09:35 AM   #2 (permalink)
Re: Vehicle Dynamic Control (VDC)
Active Brake Limited Slip still works with VDC off.
Old 01-10-2007, 09:41 AM   #3 (permalink)
Boomer135's Avatar
so I take it, auto brake will work without touching the brakes?
Old 01-10-2007, 09:59 AM   #4 (permalink)
Yeah, if a wheel spins, the SLIP light comes on, the brake engages on the rotor of the spinning wheel, you probably also will hear a ratchety noise.
Old 01-15-2007, 02:04 PM   #5 (permalink)
Titan R's Avatar
Send a message via AIM to Titan R
How would I know if I have VDC or not w/o the switch? I do have ABLS with the big tow.
stOOpidFast
Fast-Turbo.com
TFRC RsR
4drTypeR retired...
454whp@18psi pumpgas 11.5 @ 127 spinnin slicks
527whp400tq@22psi C16 (blew it running an 06 gxsr1000!!!)
Titan R is offline   Reply With Quote
Old 01-15-2007, 04:05 PM   #6 (permalink)
baseballfanz's Avatar
You should have a VDC Off switch by your Tow Mode switch.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 01-15-2007, 07:46 PM   #7 (permalink)
watermullen's Avatar
So how do you go off roading and spin your tires? I have only had my truck for a couple weeks and we finally go snow today so I tried it out in the parking lot. It seems like after a while it knows that you are intentionally spinning the tires and doesn't react for you, but I wish I could turn it off still. The brakes should only come on when I press them!
watermullen is offline   Reply With Quote
Old 01-15-2007, 07:50 PM   #8 (permalink)
chunko's Avatar
Okay that does it...
VDC and ABLS are going in best of titantalk...
2005 CC 4x4 SE
AKA
TreeHuggingHippieWhore
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
chunko is online now   Reply With Quote
Old 01-15-2007, 07:53 PM   #9 (permalink)
Possibilities include pulling the ABLS fuse, doing the mod somebody posted to turn ABLS off by switching at the fuse, installing a truetrac
Vehicle Dynamic Control Switch Install raceprep_engineering Titan General Discussion 20 02-08-2007 11:02 AM
Vehicle Dynamic Control (VDC) For XE? RigginMan Titan General Discussion 7 10-08-2006 07:33 PM
New vehicle for wife, which do you think? Aquaholic Titan General Discussion 34 09-09-2006 01:27 PM
nc vehicle law?? wmtom Off-Topic Discussion 2 05-14-2005 10:49 PM
Tow Vehicle of the Year TrojanDan Titan General Discussion 24 05-07-2004 01:59 PM
