Old 01-10-2007, 11:03 PM   #1 (permalink)
Question Remove Kick Panel?
Quick question, I need to remove the drivers side kick panel to the left of the emergency brake. I have an 05 xe titan. The panel has some type of pin in the back, I wasn't sure if this just pops off or not. I applied a small bit of pressure got the rest loose but I wasn't sure about that part.
Also anyone know where I can pick up a plate holder for the front bumper? I can't find one around town.
Black05xe is offline   Reply With Quote
Old 01-10-2007, 11:09 PM   #2 (permalink)
src4usarmy's Avatar
Re: Remove Kick Panel?
I have the same model, and I know what you are talking about but I'm not sure how it comes out. I'll look and see tommorow if nobody else chimes in. I have the front tag holder that came with mine but I don't need it if you are interested, pm me with an offer.
src4usarmy is offline   Reply With Quote
Old 01-10-2007, 11:55 PM   #3 (permalink)
Banned
mario's Avatar
Send a message via AIM to mario
yeah all u gota do is take off the first screw and the get a flat screw driver and get the little holder off not hard at u can also use the back part of a happpem or a little crow bar
mario is offline   Reply With Quote
Old 01-10-2007, 11:57 PM   #4 (permalink)
Banned
mario's Avatar
hammer*** my mistake typing on laptops at nigth suxs
Old 01-11-2007, 04:28 AM   #5 (permalink)
The pin in the central portion of the fastener acts as a wedge to retain the fastener in place. You need to use something (like a small screwdriver as suggested above) to partially pull out the central pin prior to pulling out the entire fastener. When re-installing, you position the entire fastener, and then push in the central pin to wedge it in place.
Does anyone know how to remove the side panel on the front bumper? thebassn8tr Titan General Discussion 5 05-12-2006 05:40 PM
how to remove stock kick panel cover? smoketitan Titan Visual & Audio Discussion 5 06-17-2005 12:07 PM
How Do I Remove the Door Panel?? jhawk Titan General Discussion 3 01-30-2005 04:33 PM
can't remove door panel/window handle hunka27 Titan General Discussion 8 11-08-2004 11:15 PM
XE wanting to remove Nav panel for rardar xsive11 Titan Parts & Accessories 2 06-27-2004 11:16 AM
