Old 01-11-2007, 04:16 PM   #1 (permalink)
RobKar's Avatar
Both exhaust manifolds cracked!!
Took the truck in to the shop today and dropped it off. It sounded like I had an exhaust leak. I have also been holding of on 2 other things that were minor annoyances. One was the pressure censor and the other was every now and then the AC fan will stop blowing.
2005 LE CC with ~30,000 miles
I just got the call… Will take 7 to 10 days for parts and both exhaust manifolds are cracked. Covered under warranty but ---WTF?
They are going to replace the complete system and all the pipes as well. To bad I could not get them to install a CAT back (HAHA). Anybody else had cracked manifolds?
The Tire pressure censor was simple- it was never programmed?
The AC fan motor… could not find the problem. It is an intermittent problem so I can understand how they could not find it.
AKA TrollopInTraining™ AKA chinawhore™
2005 CC LE
My wife thinks I spend to much on my truck!!
My Train Horn <-- Listen
RobKar is offline   Reply With Quote
Old 01-11-2007, 05:05 PM   #2 (permalink)
Supporting Vendor
P's Titan's Avatar
Re: Both exhaust manifolds cracked!!
think there was one other member with cracked manifolds. He did have a Flowmaster exhaust if I recall.
my mods list
USE DISCOUNT CODE FOLGER
FOR 10% OFF EVERYDAY @ www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 01-11-2007, 05:49 PM   #3 (permalink)
spoonman's Avatar
Send a message via AIM to spoonman Send a message via Yahoo to spoonman
i had one crack on me at around 22k ish, now i think the other one is too just because i hear the sound again.
04 King Cab LE 4x2
Dueler Revo At's, 17" MB Razor's, AEM Brute Force CAI , Billet Grille, NCD 2.5 inch leveling kit (not pictured), Banks Exhaust exiting after the axle. Scanguage 2
Total money spent on mods (minus wheels) = $330
spoonman is offline   Reply With Quote
Old 01-11-2007, 05:58 PM   #4 (permalink)
BRACEYOSELF777's Avatar
What exactly does it sound like?
"Chase the Dream....not the Competition."L.A. County EMT
BRACEYOSELF777 is offline   Reply With Quote
Old 01-11-2007, 06:26 PM   #5 (permalink)
konigfritz's Avatar
I think there have been a couple members. Didn't helinut have a cracked manifold?
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, JBA Cat back
Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
http://s3.bite-fight.us/c.php?uid=180006
MOΛΩN ΛABÉ
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
konigfritz is offline   Reply With Quote
Old 01-12-2007, 12:11 AM   #6 (permalink)
src4usarmy's Avatar
i just had my passenger side manifold replaced. 2005 cc xe about 25000 on it. took 15 minutes for them to find and about 4 days or so to get the parts and a day to fix it. the repair order said manifold, gasket, 16 studs, and 16 bolts. one of the guys there said it was a fairly common thing he had seen a few of them. i called to check on it the day it got fixed and he confused me with someone else with the same name having the same thing fixed on their titan.
src4usarmy is offline   Reply With Quote
Old 01-12-2007, 01:56 AM   #7 (permalink)
RobKar's Avatar
When I talked to the service rep he said that this is common with the Titans and they see this all the time. He said about 1 out of 5 have cracks and most do not even know it.
You can hear it under power and it sounds raspy, like an old car with an exhaust leak.
2005 CC LE
Old 09-22-2008, 04:45 PM   #8 (permalink)
Re: 2004 titan 38,000 Rear exhaust manifold craked!
Hi
Ok for starters I'm a woman so I realize they see me coming.....
I took my truck in today, I live on an Island so its a pain to go to the dealseship off the Island. So I had my laundry list.
E brake still doesn't hold truck, had it worked on before didn't help.
My transmission gage has been hitting high off and on while towing small horse trailer 4,500 max weight having this problem since 2006 and engine smells hot after towing for 4 miles, have had truck in several times they keep telling me its fine gear down.
I have a ticking sound when I get on the gas, you can only hear it if the window is open, other half says he can't hear it....
oh and while on my way home from canada last week my brakes started acting up , violent shuttering when braking coming down mountain pass, not a good feeling!
So yes I have had the brakes replace due to recall, the new brakes have been on for I think 10,000 miles.
So after spending 4 hours at the dealership and a day away from work and the gas to get their. The verdict is....
Brakes are bad again.......... they are going to cover the replacement again but say next time its on my dime............
They found a leak in a hose for the tramsmission cooler. I'm hoping this will stop the transmission from overheating, not confident I have seen the last of the transmission problem.
They tightened the E brake as much as possible, seems to be holding now.
And the highlight of my day.... they say my rear exhaust manifold is cracked thus the ticking sound. Oh and they say its not covered because I'm at 38,000 miles. I'm fixing to raise hell about it, I can't remember how long the ticking has been happening I think last fall??, maybe longer I dont normally drive with my windows down in the winter. I'm really frustrated because nothing has been an easy fix. I have had to make multiple trips and a 1/2 a dozen calls and everytime they just said well honey if you don't have a check engine light on everything if fine! Fine my a_ _ now they think I'm going to cough up $900.00 to fix the cracked manifold. Why would the exhaust manifold be cracked on a truck that 3 1/2 years old???
I will also be talking to someone higher up about the crappy brakes they are using as the upgrade from the crappy recalled brakes. If anyone has an advise I'd love to hear it.
Thank you
Whidbey Island Washington
So
whidbey island is offline   Reply With Quote
Old 09-22-2008, 04:54 PM   #9 (permalink)
Send a message via Yahoo to disastergrafix
My right and left maifolds were cracked when I took my truck in at 35,000 miles. I didn't know, I just got the truck then.
disastergrafix is offline   Reply With Quote
Old 09-22-2008, 05:25 PM   #10 (permalink)
baseballfanz's Avatar
whidbey island, if I'm not mistaken the manifold should be cover till 60K miles. Also if you took it in before the warranty is up and they have a record of you complaining about the noise before that they need to cover it.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 09-22-2008, 06:31 PM   #11 (permalink)
sudden urge's Avatar
Ummmm, manifolds are covered for 8 years/80,000 since they are welded to the cats. They can call Nissan and get that authorized quickly.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune in FST. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
sudden urge is online now   Reply With Quote
Old 09-22-2008, 11:44 PM   #12 (permalink)
src4usarmy's Avatar
Exactly. Do a search on here and you will find quite a few members that have had the same thing covered under the 8/80,000 warranty. Don't let them fool you.
Old 09-23-2008, 09:04 AM   #13 (permalink)
Thank you everyone for your replies! I called and talked to someone higher up at the dealership. He is looking into the issue. I will mention the 8/80,000 warrenty. I will let you know what happens.
thank you
diane
whidbey island
Old 09-24-2008, 12:09 PM   #14 (permalink)
The 80,000 warranty is for the emissions system. I've had one manifold replaced and just waiting for the other one to go. I've also had the transmission cooler line problem, and the brakes, and the e-brake. All has been fixed, thankfully.
It also took me 6 trips to the dealer before they would acknowledge that I had a leaking exhaust. It was a new guy and he didn't know about the 80,000 mile warranty! HAHAHAHA That is also when they found the transmission oil cooler line. I didn't even know about that one. It was all covered, and they thought I was going to pay for it. NOT! I hate the dealer service!!!!!!!!!!!!!!!!!!!!!
gofaster is offline   Reply With Quote
I need Stock set of exhaust manifolds 2005 Titan Redchev04 Buy/Sell 8 12-29-2008 09:22 PM
New Manifolds mobspade Titan Problems & Dealer Service 3 10-14-2006 09:19 PM
Exhaust manifolds Cptnmatt Titan General Discussion 4 09-28-2006 02:06 PM
cracked exhaust manifold JASHELL1562 Titan Problems & Dealer Service 20 11-12-2005 01:48 PM
