Old 05-04-2007, 01:45 PM   #16 (permalink)
xterraintx's Avatar
Re: Lights going out on A/C???
FOUND MY PROBLEM
It was the factory provided brake controller cable. Not exactly their fault though. The cable is just wrapped in a tape like shield. It was rubbing on something and wore through. The reverse wire was frayed bare as was the illumination wire. I guess (sometimes) when in reverse they shorted/touched taking out the fuse.
Little bit of repair and now the plastic wire wrap protection and I should be fine
Those of you with a brake controller may want to double check and see if it is rubbing before it drives you crazy too!
PS if anybody needs it I now have a spare dimmer switch
xterraintx is offline   Reply With Quote
Trailer Lights : running lights not working Chance2336 Titan Towing & Hauling 9 09-12-2006 06:33 PM
Digital dash went screwy (odometer, gear indicator lights, 4X4 indicator lights) Treebasher Titan Problems & Dealer Service 4 05-07-2005 08:27 AM
Gauge lights not lightning up when i turn on lights??? ChadEberly Titan Problems & Dealer Service 4 11-15-2004 12:17 PM
Anyone figure out how to wire fog lights to parking lights? newenglandtitan Titan Interior Discussion 9 04-19-2004 08:06 PM
