Old 01-17-2007, 11:05 AM   #1 (permalink)
Question Lights going out on A/C???
I have 35,938 miles on my Titan and no extended war. My lights on the a/c started not coming on when I turn on my headlights. It doesnt do it every time and somtimes will stay off for only 5 seconds or up to 2 minutes. This just started last week and I took it to the dealership and they said they cant duplicate the problem. Has anyone else had this problem?
Frequen.C is offline   Reply With Quote
Old 01-17-2007, 11:07 AM   #2 (permalink)
baseballfanz's Avatar
Re: Lights going out on A/C???
Try playing with the dimmer switch, turn it up and down a few times.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is online now   Reply With Quote
Old 01-17-2007, 11:19 AM   #3 (permalink)
dank78's Avatar
Yup, this was happening to me also (very recently I might add). I rolled the dimmer switch back and forthe a bunch of times (I don't know why, it just made me feel like I was actually doing something), and now it seems to be working okay.
"If idiots grew on trees, this place would be a freakin orchard!"
Mods:
* Volant CAI * 18" Magnaflow muffler * Weathertech ventvisors * 18" KMC XD Diesels (Chrome)
* Scangauge II w/blendmount * Gibson exhaust tip - 45 deg. slash * Toyo Open Country AT's 265/70R18 * Bilstein rear shocks
dank78 is offline   Reply With Quote
Old 01-17-2007, 11:19 AM   #4 (permalink)
roy365's Avatar
Works every time!!!!!!!
0-60MPH@5.82 & 1/4 mile@14.25 Passport GT Timer
Mods list: http://www.titantalk.com/forums/memb...ml#vmessage205
roy365 is offline   Reply With Quote
Old 04-05-2007, 08:26 AM   #5 (permalink)
xterraintx's Avatar
OK, kind of the same problem
I keep blowing the 10amp fuse under the hood for the AC and other knob lights. The dealer can't find the problem...said the harness would need replacing at like $650 parts and a lot of labor.
Is there a way to see if my dimmer switch might be shorting? If I remove it then none of the dash lights work
Maybe I can short the wires to the switch to bypass it in order to check? There are 3 wire connections on it. The replacement switch is $68 I'd hate to buy a replacement if mine is good.
APPRECIATE any HELP !!!!
xterraintx is offline   Reply With Quote
Old 04-05-2007, 10:04 AM   #6 (permalink)
vegastitan21's Avatar
haha i have 34000 and mine does it too.
vegastitan21 is offline   Reply With Quote
Old 04-05-2007, 12:47 PM   #7 (permalink)
helomech's Avatar
Mine does this also, I had them change the a/c control head and it didn't help. The tech told me this is a common problem and there is no real fix. Just roll the dimmer switch when it does this and it should start working.
Old 04-05-2007, 12:54 PM   #8 (permalink)
HudsonValleyTitan's Avatar
I've heard of the problem also although I've not experienced it. As mentioned, the fix was either to roll the dimmer switch or have it replaced.
- Joe
Old 04-05-2007, 12:59 PM   #9 (permalink)
helomech's Avatar
It isn't the dimmer switch that is the problem, because the dimmer switch controls all the lights and the only lights causing trouble is the a/c lights.
Old 04-05-2007, 06:36 PM   #10 (permalink)
I too have this problem with the same results at the dealer... I have 19k and an extended warr, so if I can get it there while they are "off" they will replace it... (fat chance) but they say it is "not something they have heard alot of... "
I Have sort of the same problem in my F**d work truck, in that case it IS the dimmer cuz all of the lights flicker and go out...
Never had these problems on my 71 Chevy...(they were good for burning up and sometimes catching fire) so much for technology... Still LOVE my truck!!!
Red Ryder is offline   Reply With Quote
Old 04-05-2007, 07:15 PM   #11 (permalink)
BlingAlong06's Avatar
Send a message via AIM to BlingAlong06
thats because yours is wack son
2006 SE CC 4x4 OR BT
AEM BruteForce CAI
Airraid TBS
Banks exhaust
2* TA
TB-Bypass
Leveled out
Smoked tail lights
Dark tint(Real Dark!!!)
Motometal 951s
Nitto Terragrapplers 325/60/18
BlingAlong06 is offline   Reply With Quote
Old 04-05-2007, 08:07 PM   #12 (permalink)
ohh ok son. good thing i give you all these ideas on how to make your caddywhompus *** truck look better.
Old 04-06-2007, 10:06 PM   #13 (permalink)
Shruk's Avatar
Mine started this and now that it is warming up, I noticed my A/C is not blowing cold. Not sure how much warranty I have, I did not get the extended.
Shruk is offline   Reply With Quote
Old 04-14-2007, 08:11 AM   #14 (permalink)
Saw this for the first time this week too.
Tom
05 Titan SE CC 4X4 | Deep Water | Big Tow
Pop Pkg | Utilitrack w/ extender & divider
Born on 2/05 Mine 4/05
A.R.E. LS II added 6/05 | Step Rails added 4/06
TitanTom is offline   Reply With Quote
Old 05-01-2007, 03:54 PM   #15 (permalink)
xterraintx's Avatar
OK, replaced dimmer switch today and that was not a fix. However, in the process it appears the 10 amp fuse is blowing when in reverse like the reverse lights being on are doing it. Does this make sense? I tried it twice (out of 10amps now) One blew immediately when I went to reverse to back out of garage. This is just effecting the AC switch LEDs and the console light for what gear I'm in The second one stayed for a while but blew while backing down driveway. This is not a big deal but pisses me off. What do you think about a bigger fuse?
Any ideas here? I have Big Tow and a prodigy brake controller. Was taken in for the recall for trailer wiring check too. Think the trailer harness or controller should be redone?
HELP... PLEASE!!!!!!!
Trailer Lights : running lights not working Chance2336 Titan Towing & Hauling 9 09-12-2006 05:33 PM
Digital dash went screwy (odometer, gear indicator lights, 4X4 indicator lights) Treebasher Titan Problems & Dealer Service 4 05-07-2005 07:27 AM
Gauge lights not lightning up when i turn on lights??? ChadEberly Titan Problems & Dealer Service 4 11-15-2004 11:17 AM
Anyone figure out how to wire fog lights to parking lights? newenglandtitan Titan Interior Discussion 9 04-19-2004 07:06 PM
