Old 01-19-2007, 05:40 PM   #1 (permalink)
Need help with a popping noise.
It being hunting season I have been on some pretty bad roads lately and have noticed a pretty bad popping noise.Its not when the shocks compress its just the opposite its when the shocks are extended like when going over a place where there is a sharp drop off,may only be 2 or 3 inches of drop off but for that split second the shocks extend and I get a pop,sounds like metal on metal.Thanks.
SKEET is offline   Reply With Quote
Old 01-19-2007, 06:05 PM   #2 (permalink)
Re: Need help with a popping noise.
Check for loose items in the cab or bed. Is jack and tool pouch secure? About spare tire? I had similar popping noise, so I lowered the spare tire, repositioned and coiled the extra chain and have not heard the noise since. A friend of mine asked me to check his Xterra out, said he heard a banging noise whenever he made a right turn had checked his exhaust brackets and all was OK. After riding in the Xterra, I verified his story. I don't know what made me look under the seat but I found a half empty bottle of Snapple ice-tea that was rolling and hitting the seat frame every time he made a right turn. Always check for the easy and obvious before tearing into mechanical components like shocks and suspension. Just my $.02
2006 KC, SE 4X4, BT
2004 Infiniti G35 Coupe, 6MT
Mr.TEE is offline   Reply With Quote
Old 01-19-2007, 06:50 PM   #3 (permalink)
Any leaks out of the front diff?
Old 01-19-2007, 07:11 PM   #4 (permalink)
I have checked all the obvious things but nothing.Im sure is coming from under the front of the truck.
Old 01-19-2007, 07:13 PM   #5 (permalink)
No leaks.I would know if there were any because it stays parked under the carport.
Old 01-19-2007, 07:31 PM   #6 (permalink)
sledge's Avatar
Are you positive it's coming from the front end?
For sh*ts and giggles, check you rear shakles. Sounds like the same noise I had until the shakle totally broke and the spring flew up and put a nice dent on the inside of my bed.
the weld on the shakle failed. I heard the noise for several weeks before it broke when I was wheeling, not hard but vary bouncy.
I looked at those brakets at least 10x trying to find that noise. Make sure you look close.
sledge is offline   Reply With Quote
Old 01-19-2007, 07:35 PM   #7 (permalink)
BlingAlong06's Avatar
Send a message via AIM to BlingAlong06
if you have a 2.5" leveling kit on it and its 4wd its your upper arm hitting your coil bucket
2006 SE CC 4x4 OR BT
AEM BruteForce CAI
Airraid TBS
Banks exhaust
2* TA
TB-Bypass
Leveled out
Smoked tail lights
Dark tint(Real Dark!!!)
Motometal 951s
Nitto Terragrapplers 325/60/18
BlingAlong06 is offline   Reply With Quote
Old 01-19-2007, 07:41 PM   #8 (permalink)
I get the same sound going over speed bumps. Can't figure it out either. Had it before and after 2" lift.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
Old 01-19-2007, 08:02 PM   #9 (permalink)
I only have the 2" spacer.
Old 01-19-2007, 08:25 PM   #10 (permalink)
ArmyTitan's Avatar
I have the 2" kit and my control arms hit the coil bucket, you can see the scars it has left on them
07 Silver Tundra DC 5.7L-Custom Exhaust-Limo Tint
Headlight Mod(Black)-24" Boss 330s
Gone but not forgotten
ArmyTitan is offline   Reply With Quote
Old 01-20-2007, 12:29 AM   #11 (permalink)
hey army titan you have a 2" spacer and you still hit coil bucket? i thought a 2" would fix that problem. i have a 2.5" and hit. Is there any way to prevent the a arm coil bucket connection. i dont off road on a daily basis but when i do do i just cruise slowly so i rarely top out my suspension. so im not to worried about getting a 2". the 2.5" is just a little higher which i like as well
AEM BruteForce CAI
Airraid TBS
Banks exhaust
2* TA
TB-Bypass
Leveled out
Smoked tail lights
Motometal 951s
Old 03-05-2008, 03:04 PM   #12 (permalink)
My front end bangs and clangs like crazy. People comment on it every time they get in my truck. I have a 2.5" cheep ebay leveling kit that I installed last week but it's always made the noises. I don't drive hard either, this just happens while driving down the normal roads in my city, which are in pretty rough shape lately. It even clangs when the wheels drop down over the other side of a 2" high speed bump going about 10m/h. I've had it into an alignment shop and they found nothing lose or warn. If anyone knows of a way to fix/improve this issue, I'm all ears!
black sunshine is offline   Reply With Quote
Old 03-05-2008, 03:20 PM   #13 (permalink)
MARKSOWN96's Avatar
Read into this... see post #7
Finally removed my sway bar
MARKSOWN96 is offline   Reply With Quote
Popping noise from front end MileHighTitan Titan General Discussion 38 04-18-2007 06:53 PM
Popping noise on engine start.... software.engineer Titan Problems & Dealer Service 1 09-08-2006 10:47 AM
Brake popping noise...??? warrenm Titan Problems & Dealer Service 2 09-07-2006 08:40 AM
Popping Noise When Turning JWILLS Titan General Discussion 30 08-19-2005 09:31 PM
Fixed mysterious popping noise tnbowhunter Titan General Discussion 22 01-14-2005 09:03 AM
