Old 01-21-2007, 09:01 PM   #16 (permalink)
silverbeast's Avatar
Re: 28 gallon fuel tank
when my gas light comes on i always have about 5-6 gallons still in there, so i can stll drive another 50 miles. i noticed it after filing up i was only getting about 22-23 gallons right after the light would come on.
my gas gauge drops quick right after fill up and from half to empty it takes awhile. don't really want to wait forever at the dealership for install maybe consider before the warranty runs out though.
**06 TITAN CC SE 4X4 BIGTOW**
**FLOW MASTER**
silverbeast is offline   Reply With Quote
Old 01-21-2007, 10:07 PM   #17 (permalink)
loufish's Avatar
That's about normal, these gauges aren't real accurate, and mine does the same thing, as soon as the light comes on, it's 21-22 gals to fill back up.
The TSB applies when the gauge stays about 3/4 full even when near empty.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 01-22-2007, 04:31 PM   #18 (permalink)
TitanBlue's Avatar
V8NISSANS,
OK, I'm glad to hear you don't have any unusual goals of running low on gas. I guess our gages are just more imperfect than many others! Tonight for the first time, mine sloooowly moved to full after fillup, took about 5 minutes instead of instantly.
HudsonValleyTitan,
Dropping a tank and replacing the sender in a GMC P/U runs 700-800! My mechanic shop wont do it unless we beg them to, particularly on older trucks with 200K already. Thankfully, not all shops are out to rip people off.
Many post have been made of poor gauge operation on the Titans. Our GMCs go bad at 150K fairly often.
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
TitanBlue is online now   Reply With Quote
My Answer to $3 a Gallon Fuel MX Tuner Titan General Discussion 53 05-03-2006 04:32 PM
24 gallon fuel tank gummernaut Titan General Discussion 12 04-08-2006 06:33 AM
Fuel tank Fredman5555 Titan Problems & Dealer Service 11 03-07-2006 10:29 PM
Fuel tank capacity Digi Titan General Discussion 15 12-21-2005 05:13 AM
Fuel Tank Issue ARTitan Titan Engine, Transmission & Drivetrain 13 10-15-2005 07:58 AM
