i broke 2 studs that hold the wheel to the car. called the dealer their 7.99 a piece but 250 to do the job. Is it hard to do? can some one tell me how hard it would ne to do it myself?
if they are like most cars, pretty easy to fix. you use a punch and hammer and pound out the old studs. The you have to put the new ones in. i don't know if the our wheels need a press to get them in or not. sounds like they are charging you for about 3.5 hours or more of labor. it shouldn't take them that long.
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
did this same thing on my old Maxima. Just as the previous poster said, the exisitig threaded post can be hammered thru the assembly. generally the new post will seat itself when reinstalling the tire.
As stated above if there is room behind the disc,(can you see the back of the stud?) just take a punch and drive it out. For the install I've put the stud in and put a few heavy washers (to pull against) then the lug and tighten it up and check to see thast the head is seated against the hub. I did this on a car years ago and was aprehensive then realized how easy it was. Good luck.
Clint
You have two choices in life:
Yep, as the others have said just drive the broken stud out the other side. If it is already broken it should just fall out the back. If the broken stud is still too long you will have to saw or grind it off.
2001 Polaris Sportsman 500.
What vehicle are you referring to? The Titan has 6 lugs which leaves you with four to VERY slowly and carefully go buy the parts. Better yet, can you get a ride and not even drive it?
Clint
Been there, done that, (6 lug Blazer 2 on one tire 1 on the other) drove it to the parts store and back. Had to remove the hubs to get them out. Never wanted to rotate the tires again but I hate waiting for it to be done by someone else.
I was mad and yes it did raise the level of stupidity through the roof. I did drive alot more carefully that I usually do though. (avoided the pot holes and did the speed limit = 35) Also, in my defense the part store is less than a mile away.
