Old 02-03-2007, 09:00 PM   #1 (permalink)
Not seeing the slip light when spinning
I've got a 05 CC 4x4 SE that I don't drive much and never go off road. I noticed one night while leaving a friend's house, I started spinning while backing up but never saw the slip light come on. I wanted to test the system again so I pulled of the road with one tire in the grass and the other on pavement. I power braked the truck, got the tire in the grass to start spinning, again no slip light. I had a 04 KC 4x2 before this truck and noticed several times while driving the slip light coming on when I would spin. I searched the forums and found a post that said you had to be going at least 5 mph before the abls would work. Can anyone confirm that and give some suggestions?
Biscuit'sTitan is offline   Reply With Quote
Old 02-03-2007, 09:17 PM   #2 (permalink)
BigRedTitan's Avatar
Re: Not seeing the slip light when spinning
I'm not sure what to tell you. My slip light comes on (and the engine cuts power) anytime that my back tire breaks loose, even from a stop. Does it bog down when the tire spins? If not, there may be a problem somewhere with your ABLS system. You may have to just let the dealer check this one out.
Bryan
In memory of Chris- CaliforniaTitan
2004 Nissan Titan SE Kingcab
280 rwhp/ 333 max torque
Born on 03/31/2004--Came Home on 04/15/2004
Red Brawn--Graphite/Titanium
Big Tow, Utili-Trac Package, Rockford Fosgate w/ Power Captains Chairs, Rockford Fosgate Punch P550.2 Amp, 2-Rockford Fosgate Punch P110S4 10" Subs,
AutoExtreme Throttle Body Spacer, Flo-Pro Dual Exhaust, Polished Aluminum Billet Grille, ChromeTailgate Accent, 18"X8.5" MB Offroad Gunner 6's,
265/70/18 Bridgestone Dueler A/T REVO's, Garmin nuvi 255W GPS, PRG Mini-Lift W/ 2½" Front Lift/ 1½" Rear Blocks, Bilsteins Front & Rear,
LED's Front, Eagle Eyes LED Tails, JDM 6000K HID Lows & Fogs, SilverStar Halogen High-beams, LED Third Brake Light, Red Billet Aluminum Oil Cap,
Red Active Tuning Grounding Kit, Body Colored Front Spoiler, 2 Degree Timing Advance , Clifford Matrix 50.5X Security/ Remote Start
BigRedTitan is offline   Reply With Quote
Old 02-03-2007, 09:25 PM   #3 (permalink)
NICEAWN's Avatar
Location: Several twisties and a hop skip and jump through the forest,TX
my truck cuts power a little..., and I never get a slip light either, but you cand damn sure feel the throttle working against you.
2001 Aprilia Falco 0 to 60 3.4 secs and 10.7 1/4 mile as tested when bone stock.....
2006 CC SE TEXAS ED 18 inch chromies with TOYO PROXES ST 305/60-18, 2 degree advance, stainless dual tip muffler
exhaust clips...http://media.putfile.com/ebaycanwindowsdown
http://media.putfile.com/Ebaycanwindowsup
NICEAWN is offline   Reply With Quote
Old 02-03-2007, 09:39 PM   #4 (permalink)
Didn't feel any cut in power or unusual noise. My 04 with the vdc would fall on its face as soon as you started spinning. My 05 that the question was asked about does not have the vdc.
Old 02-03-2007, 09:40 PM   #5 (permalink)
AgTitan06's Avatar
Does your new truck have the Trac package? If not, you won't see a Slip light... (I think)
Old 02-04-2007, 12:45 AM   #6 (permalink)
Leprechaun's Avatar
I have an 07 LE CC 4x2 with the traction thing too, and i've spun my tires many times, specially from a stop when it has been rainin, and i've never seen the slip light come on cept for when the whole dashboard lights up when you start the truck up. few times i'll be turnin onto a road and pretty sure i'm goin 10-15 mph and it'll spin too and light won't come on...that I've seen.
07 LE CC 4x2
red alert
22" XD Monsters in 305/45/22 Nitto Terra Grapplers
Leprechaun is offline   Reply With Quote
Old 02-04-2007, 12:53 AM   #7 (permalink)
AgTitan06's Avatar
It's very very very brief when it comes on...it won't stay on, it will flash for a second, that's about it.
Old 02-04-2007, 05:34 AM   #8 (permalink)
ptvolly's Avatar
Is there something with RPM's and defeating the system? If I'm in mud/grass/snow and floor it, I never get the light, and the system never tries to intervene at all.
If I'm driving normally and get a little wheel spin in snow/rain, the system kicks in as normal, with the slip light. (once this starts, if I floor it, the system immediately stops trying to "help"). I've done this multiple times since new, and just always assumed it was tied in to rpm or wheel speed?
**by the way, what color is everyone's slip light? I swear 2 weeks ago when we got snow, I saw the light come on GREEN, then switch to amber. I can't get it to duplicate and I hadn't been drinking, but at the time I was 100% sure I saw green at 1st!
'05 Smoke CC LE 4X4
PC 6" Stage 1
PC 8188 18X9
PC Xtreme A/T 325/65/18
Bully Dog / Magnaflow "cat-back" / Tint / NISMO CAI / 6k HID / Westin Bull w/ PIAA lights / Truxedo / Carriage Works Grill / Airlift rear bags / Bushwacker Pocket Flares
My super duper MPG doubler- a 1996 Grand Prix coupe!
ptvolly is offline   Reply With Quote
Old 02-04-2007, 12:03 PM   #9 (permalink)
Not trying to be contrary to you, but when my slip light comes on, it stays on until "control" is regained. The newer ones may be different.
...mine is always amber.
Bryan
Old 02-04-2007, 12:39 PM   #10 (permalink)
On my 04 with the vdc the slip light come on as soon as I would get wheel spin. Don't know if it was the vdc working or the abls. Just noticed the 2 or 3 times I've spun the tires on my 05, the light doesn't even flicker. Guess I'll try to spin more often and see if I can get a result. Mine is amber too when I start the truck. Don't thing I have the trac option either. Also noticed most replys that don't see the light have 05 models. Could be something with the 05's.
Old 02-04-2007, 12:59 PM   #11 (permalink)
HudsonValleyTitan's Avatar
If you have a 4X4 then you have ABLS front and rear. The TRAC package is only on 4X2s. My SLIP light comes on and flashes while the ABLS is working. I've noticed it takes a little spinning for it to activate as well. Full throttle spins, in my truck anyhow, will activate the ABLS and flash the light. Unless you have VDC, you shouldn't experience any sort of power loss. If you're that worried, have Nissan check it out.
- Joe
Old 02-04-2007, 01:15 PM   #12 (permalink)
redneckpapa1996's Avatar
I have VDC on my truck and the slip light comes on wether it is on or off....I only loose power when i have the vdc on....My lights are also amber.....
..................................BEERWHORE.................................
"THIS TRUCK IS AWESOME" !!!........"Uncle Sams Misguided Children"
Marine Corps is a department of the Navy...>"THE MENS DEPARTMENT"!!!
2004-LE-CC-BT-OR-4X4-w/VDC-Utilitrac-Pearl White---94,000 miles and still going strong!!!....."THE BIG TWUCK"!!!
2* advance, Volant gen.III CAI, TBS, Custom Flowmaster 40 exhaust w/4" duel tips, Bilstein 5100's, Weathertech floormats, Okole seat covers, Westin Bullbar w/KC Lights, Michelin LTX-AT2, Seres tail lights
redneckpapa1996 is offline   Reply With Quote
Old 02-04-2007, 02:52 PM   #13 (permalink)
I took the truck out today and found some mud and sand. I did get the slip light to come on. It took a lot more spinning and getting on it to get the light to come on than I thought it would. It definitely is not like my 04 that had the vdc system, and that is what I was kinda comparing it to.Thanks to everyone for looking and responding.
Old 02-04-2007, 03:23 PM   #14 (permalink)
Smile Re: Not seeing the slip light when spinning
I have an 06 4x4 OR w/BT and here in Montana (especially this winter), the slip light comes on very, very frequently (only when I'm in 2-wheel drive however). It really lets you know when those wheels are slipping! So far, I've been able to avoid having the VDC light come on.
Tieva is offline   Reply With Quote
Old 02-04-2007, 03:44 PM   #15 (permalink)
We don't know exactly how the ABLS system is set up to work. If may very well be set up that as long as the truck is moving forward enough, it doesn't bother. Which means it would have to see the front ABS sensors to know you're moving. It may try and save the brakes until you're really stuck....or at least moving very slowly like you need help. That's just a guess. It could also be that it's just the nature of the machine....some trucks will kick in the ABLS before others will. As long as the ABLS is working, I'd be ok with it.
- Joe
VDC off and SLIP light illuminated marc.krueger Titan Problems & Dealer Service 3 11-13-2006 01:50 AM
SLIP light staying on imjustdamngood Titan General Discussion 6 10-19-2006 01:40 PM
slip and brake light nytitan1 Titan Problems & Dealer Service 4 10-14-2006 05:51 AM
First snow slip light came on and I have no VDC. A2titan Titan Problems & Dealer Service 9 11-24-2005 09:34 PM
SLIP light in dash comes on dooboy2112 Titan Problems & Dealer Service 6 08-30-2005 09:56 AM
