Old 02-05-2007, 09:07 AM   #1 (permalink)
jmeyer's Avatar
Cold transmission question
This morning it was -1 out. I started the Titan and let it warm up for about five minutes before I left the house.
After I hit the road, the transmission was shifting extremely hard. I have been in much colder temps and this has not happened before.
Any suggestions or anybody have this happen before???
Thanks for your help guys.
All I ask is that you just show up for whork!
HandyWhore™
jmeyer is offline   Reply With Quote
Old 02-05-2007, 09:45 AM   #2 (permalink)
Re: Cold transmission question
I have a '07 KC SE and I noticed the same thing this morning. It was -6 and I let it idle for a few minutes. Jumped in and took off (slow). I knew the engine was getting warm but the trans was still cold. I noticed it shifted pretty hard as I picked up speed. Within a half mile it was back to normal. At first I was concerned, but later realized it was normal. Just go easy until the transmission is warmed up.
'07 KC SE (484 miles)
cnett is offline   Reply With Quote
Old 02-05-2007, 10:59 AM   #3 (permalink)
I have heard that leaving your vehicle running does not heat up the trans fluid, but putting it in neutral and letting it runs does. So after the motor is warmed up you may want to sit in the vehicle and let her sit in neutral for a minute before taking off. We are -20 here today, so I'll see how she shifts this afternoon...
Yomama -
2005 4x4 Canteen Crewcab SE with BT, OR, Utiltrak and Popular Package.
Ziebart rust proofing
A.R.E. Z series topper
Myron and Davis DVD for the kiddies, DDX7015 for me Kenwood amp and lightning amp on 8" polk sub. Audiovox remote starter (with satellite link)
Zoomers (No Drone) exhaust
AEM intake
Stillen Headers
2002 Hyundai Santa FE (The wifes)
2001 Polaris 700 Twin ATV
1996 28' Bayliner Cierra Sun
http://www.yomama.net
Yomama is offline   Reply With Quote
Old 02-05-2007, 11:07 AM   #4 (permalink)
Gunner22's Avatar
Mine does that too on the subzero mornings. It was -20 this morning and it took a while for the tranny to start shifting smooth. I drove it around town for maybe a mile at slow speeds before I drove at highway speeds just to get some heat in the drivetrain. Not sure what can be done to help prevent the hard shifts in the cold weather.
2005 SE KC 4x4: Bedliner and Floor Mats ... thats it.
Add ons: 2* Timing Advance, Extang Black Max Tonneau Cover, OEM Fog Lamp Kit, OEM Hitch Package, Lund Hood Shield, Amsoil EaA104 Air Filter, Earnhardt "Intimidator" License Frame.
Adopted: December 10, 2005
Mileage: 32,445
Gunner22 is offline   Reply With Quote
Old 02-05-2007, 11:09 AM   #5 (permalink)
Gunner22's Avatar
I have never heard of doing that, but it makes sense. I'll have to try it as well this afternoon.
Mileage: 32,445
Old 02-05-2007, 11:20 AM   #6 (permalink)
Send a message via Yahoo to Bartek101
Exclamation Re: Cold transmission question
Same thing here, it was -11F this morning and the trans felt like it had SHIFT-KIT installed until fluid has warmed up..
2006 se, KC, Texas edition, Stock(for now)
Bartek101 is offline   Reply With Quote
Old 02-05-2007, 02:44 PM   #7 (permalink)
When it's cold out I always shift mine into neutral as soon as I start it and let it sit there for at least a minute or two to warm up. I used to do this on my Dodge Ram because the trannys on them wouldn't circulate fluid in park. I have no idea if it does on the Titan but I'd rather be safe than sorry. I always drive away with very little throttle so when it first shifts it's not under any load.
M_Dizzo is offline   Reply With Quote
Old 02-05-2007, 05:32 PM   #8 (permalink)
loufish's Avatar
Did you mean leaving it in Park does not put much heat into the trans? Park/Neutral is the same far as the torque converter is concerned, if you let it sit in gear for 5 minutes you put more heat into the fluid because it loads up the converter a little. You guys are way off the normal cold temps, and could have several powertrain issues until things warm up...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Transmission Question??????? jdavisjr8 Titan Engine, Transmission & Drivetrain 14 07-12-2006 07:06 PM
morning transmission temp question rodney Titan General Discussion 7 04-18-2006 10:31 AM
Transmission question brentburgess171 Titan Problems & Dealer Service 2 02-02-2006 03:03 PM
Question about cold weather and 3M double-sided tape LANDMAN Titan General Discussion 5 12-15-2005 01:03 PM
Cold Drivetrain question... TITANTX Titan Engine, Transmission & Drivetrain 6 12-15-2005 03:29 AM
