Old 02-07-2007, 12:47 PM   #1 (permalink)
rabbit59161's Avatar
Slipping tranny...
I recently had my first problem, the dealership said I have been the only one in the history of Titan owners to have this problem. (ok) Every single dash indicator was going off hard core. I just happened to be going past a nissan dealer so I pulled in & parked. I looked in my indicator dictionary, couldn't figure it out so I went inside, they said they would look at it. 3 hours later I found out I had lost every drop of AMSOIL tranny fluid I put in it but luckily didn't loose the tranny itself. I guess the 2 botton bolts came loose some how. It took 5 hours total because the dealership had to find an AMSOIL dealer to replace the fluid. I told them I swear by this stuff & will have nothing else in my truck or quads.
rabbit59161 is offline   Reply With Quote
Old 02-07-2007, 12:55 PM   #2 (permalink)
Elias60's Avatar
Re: Slipping tranny...
I don't see any info on your truck, like what year ?what trim ?what kind of drivetrain? Sorry, but I am having a hard time buying your story.
05 Nissan Titan LE CC Smoke BTW 4X4 ARE Tonneau
Elias60 is offline   Reply With Quote
Old 02-07-2007, 06:27 PM   #3 (permalink)
loufish's Avatar
Which bolts? Did you pull the tranny pan to change fluid(do we have a drain plug on our trans?)
Stick around and fill in the missing blanks, would you...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 02-07-2007, 07:13 PM   #4 (permalink)
I thought that I read somewhere that your warranty will be voided if you use anything other than j-matic nissan tranny fluid
jree is offline   Reply With Quote
dry tranny catchandkill Titan Engine, Transmission & Drivetrain 6 02-04-2007 10:53 AM
Tranny Slipping Badingo Titan Problems & Dealer Service 7 04-13-2006 07:27 PM
Slipping feeling after I put in drive and hit the gas Wiscdave Titan Engine, Transmission & Drivetrain 9 04-21-2005 02:12 PM
slipping on a flowmaster on stock piping BIGT56PA Titan Performance Modifications 17 04-20-2005 05:58 PM
titan transmission slipping solidaxlenissan Titan Engine, Transmission & Drivetrain 6 04-14-2005 12:59 PM
