Old 02-09-2007, 10:36 AM   #1 (permalink)
watermullen's Avatar
Tire Pressure Sensors with Two Sets of Wheels
If I have two sets of rims/tires, both with tire pressure sensors installed, do I have to get the dealer to reprogram them every time I switch tires?
Also, I understand that if you remove the tire sensors and put them on new wheels, you have to put them back in the same location they were on the vehicle or else they won't work properly. So how do they work when you rotate the tires? Nissan reprogram again?
watermullen is offline   Reply With Quote
Old 02-09-2007, 12:43 PM   #2 (permalink)
tazstitan's Avatar
Re: Tire Pressure Sensors with Two Sets of Wheels
Yes... the BCM only has slots for 4 TP sensor numbers..
When tire rotation is done - most dealers do not re-adapt sensor location, that would be a added charge - if not readapted after rotation the problems would be :
1. Navi if equiped would say - left front is low but its really left rear..
2. NON navi equiped - have a noise (tone) that peeps to tell you which one is low but again its just in the right spot.
tazstitan is offline   Reply With Quote
Old 02-09-2007, 12:51 PM   #3 (permalink)
tnbowhunter's Avatar
I have two sets of tires & wheels that I switch out for summer and winter driving both sets have the sensors installed. I have never had to have them re-programed. I just switch them out and go with no problems.
Also, there is no need to put the tires back in the same location, whoever told you that was misinformed.
2001 Polaris Sportsman 500.
Old 02-09-2007, 07:22 PM   #4 (permalink)
Sounds good, I was hoping it would work that way but other threads I've seen on here say otherwise. Anyway, I got the new ones on today so hopefully the light doesn't come on.
Old 02-09-2007, 07:30 PM   #5 (permalink)
Blackbeauty's Avatar
Tnbowhunter has the plan. The manual states that the NAV optioned Titans will display the pressures and the warning lights but the pressures are randomly displayed and don't necessarily corresond to any specific order or sequence. It is meant to be a warning (thanks to the Furd Exploder) that there is something you need to address, but it will not pinpoint which tire is low. They want you to check ALL of your tires for safety reasons.
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 02-09-2007, 09:37 PM   #6 (permalink)
70DATSUN's Avatar
Go ahead and change your tires. You won't have any trouble with your sensors. There is no order too the way they read. I rotate my tires with no problems. I have Nav in my truck and the manual states that there is no order too the sensor reading.
70DATSUN is offline   Reply With Quote
Old 02-10-2007, 07:33 AM   #7 (permalink)
Let us know how it goes. As I said earlier I change mine out and rotate them without a problem. My truck dosen't have Nav on it so there may be a difference.
Old 02-10-2007, 07:16 PM   #8 (permalink)
Yeah I don't have nav either. I have the new tires on and no problems yet but the guy I got them from said that after he drove 30 mins the light would come on. He said it was because he didn't get them put back in the same locations. Obviously that doesn't matter, so maybe one of them is messed up or something. I'll let you know when I've drove more than 30 mins if the light comes on.
Old 02-11-2007, 04:54 AM   #9 (permalink)
thclimer's Avatar
I have two sets of rims/tires; both with tire pressure sensors installed. The second set of rims I obtained I put snow tires on, after driving about 50 miles with them the light came on and has been on ever since. When I put my original rims/tires back on in the spring it will be interesting to see if the light goes out. I've always assumed the light came on because each TPS need to be configured to your vehicle and I never had them configured. Maybe there is just something wrong with one of the TPS from the second set.
2006 LE KC 4X4 BT, Radiant Silver
Prodigy Brake Controller
Equalizer Hitch
Scan Gauge II
Firestone Air Springs
Bridgestone Dueler A/T Revo's
A.R.E. Z-Series Cap
thclimer is offline   Reply With Quote
Tire pressure sensors less than 30k WhiteTitanSe Buy/Sell 1 07-16-2006 09:52 PM
Tire Pressure Sensors (Centerline Wheels) FFtitan Titan Wheels, Tires & Brakes 5 05-03-2006 05:52 PM
Tire Pressure Sensors cmclovis Titan Wheels, Tires & Brakes 6 01-23-2006 08:25 PM
WANTED: set of tire pressure sensors for 2005 Titan wheels C4RACER Buy/Sell 4 12-28-2005 05:33 PM
Aftermarket Wheels and Tire Pressure Sensors 4FV Titan General Discussion 10 12-21-2004 09:16 PM
