Old 02-10-2007, 04:35 PM   #1 (permalink)
DWBTITAN421's Avatar
Battery Question
So my day started out at 7am this morning doing various chores, The titan starts up as it normally does. It does this several times during the morning no problems starting. Later in the afternoon I went to start up and nothing. Drew a blank, it wouldnt even turnover, just a bunch of clicking sounds. I immediately figured it was the battery so I called a friend to try to get a jump. After trying several times to jump my truck, nothing happened. So I called AAA, they came out and they tried to jump my truck and they too were unsuccessful. Finally I had run to Sears to purchase a new battery, which by the way they only have one kind avaiable for our trucks for $113. So I finally got the battery in after about 3 hours of trying to jump the truck. So has anyone encounter this problem yet? and does anyone know how long the factory battery is supposed to last? I've had my 04' for 2 and half years now. Also I did not leave any lights or any equuipment on while I left my truck>
DWBTITAN421 is offline   Reply With Quote
Old 02-10-2007, 05:15 PM   #2 (permalink)
NorCalTitan916's Avatar
Re: Battery Question
I bought my 05' in November and the battery was dead in December. I think for mine the dealer had it on the lot for awhile, then it would go dead, they'd charge it, on so on.
I think the stock batteries just suck, so just replace when needed and fear not for the future!!!
2005 CC SE w/ BT
Now Playing: S&B Intake, MagnaFlow 18" SIDO Muffler w/ 3" Tips, Stillen Front Sway Bar, 2* Timing Advance, WeatherTech Floormats, OEM Foglights
Coming Attractions: Lower X-Grill, Tonneau cover, New Shoes?
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
NorCalTitan916 is offline   Reply With Quote
Old 02-10-2007, 05:20 PM   #3 (permalink)
redneckpapa1996's Avatar
My truck is 3 yrs old this month and my factory battery is still doing good...I hope i don`t jink myself by posting this...I do have the bigger battery...Good Luck
...................................BEERWHORE™.....................................
"THIS TRUCK IS AWESOME" !!!........"U S M C" !!!
!!!!!!!!!!!!!!!!!!!!!!!! "GO TITANS" !!!!!!!!!!!!!!!!!!!!!!!!!!
2004-LE-CC-BT-OR-4X4-w/VDC-Utilitrac-Pearl White
2* advance, Volant CAI, TBS, Flowmaster 40 series w/4" duel tips, Bilstein 5100's, Weathertech floormats, Okole seat covers, Westin Bullbar w/KC Lights
redneckpapa1996 is online now   Reply With Quote
Old 02-10-2007, 05:25 PM   #4 (permalink)
titanss's Avatar
I would be worried if you bought a diehard battery. Had one in my chevy, it started fine when i left work drove about 70mi. [baton rouge to hammond] to buy some items, jumped in the truck and the battery was dead. Tried to jump start it with 3 different cars and 2 different sets of jumper cables, had to replace the battery to get home. I will never own another diehard battery again.
Old 02-10-2007, 05:34 PM   #5 (permalink)
TitanBlue's Avatar
I am assuming you have an 04, going by your join date. I'd say you experienced a sudden loss of continuity in the battery, due to age/wear. Being a maintenance free battery, it could have been low on water for some time, and finally died completely. i've seen this many times (sudden failure).
A broken post (internal) can cause it (caused by vibration).
We recently had a pickup (not a Titan) that needed jumped a couple times, but last start sounded normal. Then it would not start again, so we cleaned terminals, and replaced cables ends. Turned key to start, and the battery exploded!
No water was evident from the explosion at all! Apparently a very dry battery that worked almost to the end. Amazing event. Reinforced need to check fluid level before charging and need to have safety glasses on when working around the battery (charging, etc.), though no one was hurt.
Average battery last 3 years, maybe 5. It is the suddeness of the failure that surprises us at times. But all seems well with your truck. Do get a free Alternator/Battery test done at the local parts store.
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Tow Battery? ccgobama Titan Towing & Hauling 12 01-05-2008 09:20 AM
Battery question?? cajundohboy Titan General Discussion 28 02-08-2007 02:23 PM
Battery help WazzuCoug Titan General Discussion 18 03-08-2006 12:51 PM
A second battery? Keven Titan FAQ & Howto Area 2 09-25-2005 07:36 AM
