Old 02-18-2007, 07:41 PM   #1 (permalink)
Send a message via AIM to Work Horse
How do I turn off the traction control?
Can I turn off the traction control?
If so, where do I turn it off?
Thanks in advance.
Work Horse is offline   Reply With Quote
Old 02-18-2007, 07:44 PM   #2 (permalink)
helomech's Avatar
Re: How do I turn off the traction control?
If you have vdc you can turn it off with the switch, if you don't have vdc you don't have traction control. It is on the dash, either on the left by the pedal adjustment, or the right by the tow mode switch.
helomech is online now   Reply With Quote
Old 02-18-2007, 07:46 PM   #3 (permalink)
FuzzyLogic's Avatar
Thanks in advance.
Traction control should turn off when you go into low-range if you have 4wd.
It's not rocket surgery.
'06 CC 4X4 SE Born Oct. 05
Big Tow
Eclipse GPS Navigation/DVD/CD (Dealer Option)
Smoke
World's fastest beer cooler (see photo gallery for explanation)
FuzzyLogic is offline   Reply With Quote
Old 02-18-2007, 07:46 PM   #4 (permalink)
redneckpapa1996's Avatar
I think you are talking about VDC, which on a Titan is pretty much the same...If you have it, there should be a switch below the radio right beside the tow/haul mode switch.....
...................................BEERWHORE™.....................................
"THIS TRUCK IS AWESOME" !!!........"U S M C" !!!
!!!!!!!!!!!!!!!!!!!!!!!! "GO TITANS" !!!!!!!!!!!!!!!!!!!!!!!!!!
2004-LE-CC-BT-OR-4X4-w/VDC-Utilitrac-Pearl White
2* advance, Volant CAI, TBS, Flowmaster 40 series w/4" duel tips, Bilstein 5100's, Weathertech floormats, Okole seat covers, Westin Bullbar w/KC Lights
redneckpapa1996 is online now   Reply With Quote
Old 02-18-2007, 08:10 PM   #5 (permalink)
Hmm...I dont have the VDC Switch.
I do know I have traction control though. I just can't find out how to turn it (on and off) whenever I want to. Whenever I spin the wheels, the B-LSD indicator light goes on and the wheels stop spinning.
Note that I have one of the earlier Titans. My truck was made in December 2003.
There must be some other way to turn it off.
Maybe in the fuse box? I don't know. That was just a wild guess.
Old 02-18-2007, 08:18 PM   #6 (permalink)
helomech's Avatar
No what you have is the abls limited slip. The light is just telling you that the abls is active. There is no way to turn it off.
Old 02-18-2007, 08:24 PM   #7 (permalink)
So I guess doing burnouts isn't a safe thing to do in this truck then? lol
I can't seem to do them without the wheels locking up. lol
Although I did see one of the car reviewers on the (ESPN Auto Show) show, do a HUGE burnout at the end of the review he did and I always wondered how he did that.
Old 02-18-2007, 08:28 PM   #8 (permalink)
helomech's Avatar
The wheels shouldn't lockup, whatever wheel spins the brakes should grab that wheel to make the power go to the other wheel. The brake should only slow the wheel down to the same speed as the other wheel.
Old 02-18-2007, 08:37 PM   #9 (permalink)
Maybe it isn't locking up. But I do feel a huge quick shake and a thumping noise whenever I try to spin the back wheels.
I'm probably pressing on the accelerator too hard or something. It's very difficult for me to keep the back wheels spinning continuously for more than 3,4 or 5 seconds. You have a nice truck btw.
Old 02-18-2007, 08:40 PM   #10 (permalink)
helomech's Avatar
Maybe it isn't locking up. But I do feel a huge quick shake and a thumping noise whenever I try to spin the wheels.
Thanks. 3 - 5 seconds is a pretty long time for a truck to spin the tires. Mine will usually swap sides with the black marks, sometimes it will leave 2 black marks. In 3 seconds my truck is going fast enough that it won't be spinning by then.
Old 02-18-2007, 08:45 PM   #11 (permalink)
Starting to smell something, the old lady must have farted.....
Old 02-18-2007, 08:50 PM   #12 (permalink)
Oh okay so your truck can pretty much do the same kinds of burnouts my truck can do.
What about those noises I mentioned? Do you get the thumping noise sometimes ? Do you feel a little bit of a jerk sometimes? Again, I'm sure these noises are a result of me pressing the accelerator too hard but I'm just wondering if this kind of thing happened to you as well.
Old 02-18-2007, 08:56 PM   #13 (permalink)
helomech's Avatar
I don't get any kind of noise when the tires are spinning, but my hearing isn't the greatest. I do hear the abs making terrible noise when it activates on slippery roads, but that is normal. Maybe you are hearing the abs working.
Old 02-18-2007, 09:01 PM   #14 (permalink)
If the abs works on the back wheels (since those are the wheels I'm spinning) then thats probably what I'm hearing or feeling then.
Or its the abls which is also what you mentioned earlier.
Old 02-18-2007, 09:11 PM   #15 (permalink)
helomech's Avatar
The abls uses the abs to act as a limited slip differential (aka posi traction). Our trucks have an open differential, that means that the power from the engine will go to the tire with the least resistance, so the truck uses the brakes to slow the spinning wheel so that the other wheel is the one with the least resistance.
headlight control on turn signal Taylor Titan Interior Discussion 13 01-21-2007 03:59 PM
stability control traction system? Roadrunner Titan General Discussion 8 12-30-2006 11:00 AM
VDC Traction Control on Titan XE All Wired Titan General Discussion 1 10-10-2005 11:20 AM
ABLS vs. traction control vs.VDC richardminco Titan General Discussion 7 09-15-2004 02:03 PM
