Just changed my front and rear diff fluids today (M1 75w-90 abd M1 75w-140), was the first time for the front and the second time for the rear (I'm at 31k miles). I changed the rear fluid at 5k but wasn't concerned about the front because I was under the impression that the front diff only spun when in 4wd. Well to my dismay I was informed that the front diff spins all the time, oops. Sooooo changed that today. The sludge, errr fluid was pretty gross in both diffs, glad I got around to changing them.
Well just a heads up cause I figure a lot of people were probably under the same impression about the front diff that I was.
__________________ When someone smiles at me all I see is a chimpanzee begging for its life.
I changed my front for the first time at 35K and it looked pretty good. I put full syn in both front and rear. the rear was nasty, it had been changed once already.
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
Replaced the fluids in the rear diff at 29K......comparing the fluid colors..old fluid.....dark brown...the new fluid....light yellow. Big difference. It says on the diff cover.....75W-140W Synthetic only. 06 diff's take 2.25 quarts.
2006 Nissan TITAN XE KC. Totaled 11-13-2008. REST IN PEACE.
Chris how many bottles of gear lube did the diffs take each. I am at the 30K mark and need to change them. Nissan for some reason didn't list that in my manual, says to see dealer. FT!!! PIA!!!
Thanks
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC SE
Big Tow
4x4
Silver
Is filling the front diff. done like the rear diff.--Plug in the side and fill until it starts to run out a little ??????Thanks
You know the drill....first drain the old stuff out.....and fill them up until they start to over flow then just plug em up....takes less than 30 minutes...thats draining and filling all together.
