Old 02-23-2007, 04:13 PM   #46 (permalink)
StuntDriver06's Avatar
Re: I actually got 423 miles on one tank - wow
Originally Posted by LAfirefytr
How do you correct for tire size when computing MPG? I just went from 245/75/17 to 325/60/18 and of course my MPG has taken a HUGE hit. I'm just curious about how you correct for tire size and if maybe the way I'm calculating now (I divide the number of miles on my trip meter by how many gallons it takes to refill truck) needs to be adjusted somehow because of the new tire size?
ok, if this is on your titan the stock size tires are 32.7 inches.... the new size for yours is 33.35 (325/60R18) so divide new size by stock size and get 1.01... so take that number and multiply it by your trip meter reading and use it for milage..... so if it was 300 miles read on dash * 1.0198776758409785932721712538226 you get 305.96 which is basically 306 miles.... not much of a difference..... however, if you had 245/75R17's and were using the milage from that then it would be a bigger difference.. so if you drove 300 miles on the 245 17's you should have calculated for 288 miles.... i hope i explained it clear enough....
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Old 02-23-2007, 08:04 PM   #47 (permalink)
Advocate07's Avatar
Send a message via AIM to Advocate07
^^Smarty pants.. :P
Advocate07 is offline   Reply With Quote
How many miles do you guys get on a full tank? TranMan409 Titan General Discussion 62 10-20-2007 03:48 PM
over 400 miles in one tank tom0445 Titan General Discussion 42 12-07-2006 08:53 AM
Miles per tank of gasoline? Birdman Titan General Discussion 58 11-21-2005 11:39 PM
How many miles are you getting on a 1/4 tank? Birdman Titan General Discussion 9 10-04-2004 09:33 AM
390 miles on one tank! RedMunsta Titan General Discussion 16 06-22-2004 06:28 AM
