Old 02-21-2007, 08:21 AM   #1 (permalink)
Popping noise in front end
I posted this on another Titan forum...but got no suggestions, so here goes here...
I have a popping noise under the floorboard. It happens when I let off the brakes and hit the gas. Nissan says its "play" in the driveshaft. I've never owned a vehicle that had that. Anyone have any suggestions??
Kentc1978 is offline   Reply With Quote
Old 02-21-2007, 05:31 PM   #2 (permalink)
CJ3FLYR's Avatar
Re: Popping noise in front end
Kent, I just had mine fixed. It was a very similar problem to what you descibed. My 05 suffered from a loose transmission mount on the crossmember. I addressed a long time ago but as I approached 30k the 'pop' started. Southerlin in Ft Myers spent a ton of time and effort. They checked a bunch of stuff and the culprit was a loose motor mount. Due to normal road smeg they loosened, cleaned, sprayed and retorqued the motor mounts and it worked.
Chris
Chris
05 Blizzard LE CC, 4x4, BT, OR, Nav, AB, Sunroof, XM, Ceramic Pads on new rotors & hardware (10.2k+miles,no brake issues to date and very clean wheels), AutoExtreme TBS, TB coolant bypass, Inverted helper springs, Hi-capacity diff cover, Active Tuning ground kit, poly swaybar bushings (front), Axle Vent Mod
CJ3FLYR is offline   Reply With Quote
Old 02-22-2007, 06:51 AM   #3 (permalink)
Thanks for the reply Chris, glad it worked out for ya. I'll give my dealer a call and ask him to check it.
Need help with a popping noise. SKEET Titan General Discussion 12 03-05-2008 02:20 PM
Popping noise from front end MileHighTitan Titan General Discussion 38 04-18-2007 05:53 PM
Popping noise on engine start.... software.engineer Titan Problems & Dealer Service 1 09-08-2006 09:47 AM
Brake popping noise...??? warrenm Titan Problems & Dealer Service 2 09-07-2006 07:40 AM
Popping Noise When Turning JWILLS Titan General Discussion 30 08-19-2005 08:31 PM
