Old 02-24-2007, 12:13 PM   #1 (permalink)
RyanF's Avatar
How 4 cents might save you big $$$
Ok, so I know a couple people have had a problem with the tailgate falling out of the left side hinge when it is down and you hit a bump. I had an expensive expirence where I had a quad in the rear of the truck, hit a bump and the tailgate fell out of the left side.. Not knowing this i kept driving, with the weight of the quad partially on the tailgate, pushing it down into the bumper.. In short the whole back of my truck needs to be repainted, and the top of my bumper needs to be replaced...
My soulution?
A standard zip tie around the left hinge of the tailgate will solve all your problems.. Its hardly noticable, easy to remove, and CHEAP.. It will keep the poorly designed hinge from costing you money..
Just thought I would share my expericence and solution.
-Ryan
RyanF is offline   Reply With Quote
Old 02-24-2007, 12:19 PM   #2 (permalink)
HudsonValleyTitan's Avatar
Re: How 4 cents might save you big $$$
If the tailgate is FULLY open (or fully closed), I don't see how it can come out. It has to be open at a 45* angle to get it off. There shouldn't be anything else needed to keep it in place. If it's open all the way or closed all the way, it should be fine. Did you have it somehow held partially closed? If not.....there's a defect in your hinge.
- Joe
Old 02-24-2007, 12:48 PM   #3 (permalink)
redneckpapa1996's Avatar
What he said....
...................................BEERWHORE™.....................................
"THIS TRUCK IS AWESOME" !!!........"U S M C" !!!
!!!!!!!!!!!!!!!!!!!!!!!! "GO TITANS" !!!!!!!!!!!!!!!!!!!!!!!!!!
2004-LE-CC-BT-OR-4X4-w/VDC-Utilitrac-Pearl White
2* advance, Volant CAI, TBS, Flowmaster 40 series w/4" duel tips, Bilstein 5100's, Weathertech floormats, Okole seat covers, Westin Bullbar w/KC Lights
redneckpapa1996 is online now   Reply With Quote
Old 02-24-2007, 12:58 PM   #4 (permalink)
baseballfanz's Avatar
If it's open and you drive on rough surface, that thing can bounce and come off. Had peoples reported that already. The zip tie trick been discuss before.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 02-24-2007, 02:12 PM   #5 (permalink)
RyanF's Avatar
It was all the way open..
Open yours, then lift it a little bit and start shaking it, mine will come out.. It has actually fallen out once when my friend was closing it too (dont know what the hell he did) I should have put a zip tie on it then.. Oh well..
Old 02-24-2007, 03:02 PM   #6 (permalink)
I posted this problem almost three years ago.
http://www.titantalk.com/forums/139211-post1.html
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 02-24-2007, 08:31 PM   #7 (permalink)
Unless it's broken though, you had to hit a bump that was big enough to force the tailgate to swing up to a 45* angle ...which can then pop out. I bet the newer trucks with the damped tailgate opener/closer would be harder to bounce like that. I've driven with mine open before but nevr on roads rough enough to do that. And it probably had an ATV in the back which would hold it down anyhow.
- Joe
Old 02-25-2007, 02:38 AM   #8 (permalink)
loufish's Avatar
My last truck was a Ford Ranger and did that the first time I hauled bikes with t-gate in the 1/2 way position.
I fabbed a curved piece of sheetmetal to cover the slot opening, but it was removable with 2 screws in case I ever had to take off the t-gate.
That was the end of that problem...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 02-27-2007, 11:05 AM   #9 (permalink)
RyanF's Avatar
Actually my tailgate seems like it closes easier than my friends '04 that didnt have the dampened and spring assisted gate..
You're 2 cents on these 18 inch tires?? ibbodyboarder Titan Wheels, Tires & Brakes 11 09-03-2006 08:34 PM
look what i just got to save on gas teamevolutionstitan Titan General Discussion 9 07-04-2006 01:23 AM
2 cents about Leveling/Lift kits shaeboy Titan Parts & Accessories 39 01-14-2006 04:02 PM
Ethanol for 85 cents in SA Today Ants05SE Texas Forum 11 11-03-2005 01:39 PM
Here's My Two Cents consideringtitan Titan General Discussion 5 03-12-2005 08:50 PM
