Old 02-27-2007, 06:35 AM   #1 (permalink)
Questions on 3rd Brake fix???
I posted this in the Brake Recall Info. Sticky but it was on page 28 and I got no responses.
My 2005 Titan CC went for its 3rd brake repair today and also a leak under the master cylinder. They told me I have to leave it because of the leaking hose and because they have to overnight the front Rotors for the permanent brake fix that I made sure that I mentioned when I brought it in. They said they are just replacing the rotors in front and brake pads in front only because there wasn't any issues with the rear brakes?? I thought that the permanent fix calls for new rotors and new brake pads in front and resurfacing the rear rotors and new brake pads in rear??? Am I mistaken???
In the TSB for the brake fix under actions, it clearly says to do all that I stated above. After I talked with the service manager, He said that he is aware of the TSB's and not everyone coming in with a brake issue gets pads and rotors all the way around. I told him It didn't say anything about replacing the rear rotors unless they can't be resurfaced!!!!! I left it at that and called Nissans Consumer Affairs and complained to them (only because I didn't like his attitude). We'll see what happens. The dealer use to be O.K. Looks like I have to find a different dealer. My Truck is currently at Pine Belt Nissan in Toms River, New Jersey.
Am I reading the TSB wrong for the permanent fix or what??? Please let me know if this is what you recieved with your 3rd and final brake repair??? Thanks, Eddie
2005 Titan Red Brawn CC 4x4
emcg24 is offline   Reply With Quote
Old 02-27-2007, 07:57 AM   #2 (permalink)
Re: Questions on 3rd Brake fix???
Obviously you want to get everything you can, but my rear brakes barely show any wear. Depending on mileage, your rear pads & rotors may be essentially in new condition. Turning good rotors down w/o reason is generally not a good idea.
Old 02-27-2007, 11:35 AM   #3 (permalink)
Thanks for the reply. I was basically reading the actions on the TSB and it also says replace the rear brakes with the NEW brake kit. Oh well, whatever it is it is. I just didn't want to get screwed over. Thanks again for the reply. Eddie
Brake box install questions. Helinut1970 Titan Towing & Hauling 7 07-27-2006 05:25 AM
Brake controller questions sapper1971 Titan Towing & Hauling 7 05-05-2005 05:15 AM
Prodigy Brake Controller - initial setting questions Titan Ken Titan Towing & Hauling 4 03-08-2005 07:14 PM
Trailer Brake Questions RodsTitan Titan Towing & Hauling 18 08-25-2004 06:17 PM
Warped Brake Discs and other Myths - A Brake Primer Steve04SE Titan General Discussion 4 06-03-2004 01:44 PM
