Old 03-04-2007, 03:11 PM   #1 (permalink)
BlingAlong06's Avatar
Send a message via AIM to BlingAlong06
Squeky belt
so i took off my radiator cap to look in the radiator.(dont know why) and i got side tracked and just set it back on the fill spot w/o tightening it back down. i went for a drive smelt coolant. i stopped saw what i did let aout a few choice words, put the cap back on. then i went to the dealer and got a gallon of coolant. i got home let my motor cool sprayed my engine off w/ the hose to wash off the coolant. the next morning i go out and start it up and it sounded like there was a cat stuck in my fan. i got some WD40 and sprayed it onto my pullies and belt and it went away but when the WD dries up it does it again. Any way to stop a squeky belt. truck only has 8700 miles. i think the the hard water coming out of my hose got some deposits of minerals into my alternator bearings... any help would be appreciated...thanks clint
2006 SE CC 4x4 OR BT
AEM BruteForce CAI
Airraid TBS
Banks exhaust
2* TA
TB-Bypass
Leveled out
Smoked tail lights
Dark tint(Real Dark!!!)
Motometal 951s
Nitto Terragrapplers 325/60/18
BlingAlong06 is offline   Reply With Quote
Old 03-04-2007, 03:44 PM   #2 (permalink)
helomech's Avatar
Re: Squeky belt
I wouldn't recommend wd-40, they make some stuff called belt dressing. Or you could just change the belt only like 20 bucks.
helomech is online now   Reply With Quote
Old 03-04-2007, 03:45 PM   #3 (permalink)
Carbeaux's Avatar
Re: Squeky belt
Bingo on the belt. It's a pretty cheap one. I'd swap that out for a new one and see what happens.
Hook 'Em Horns!
A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America' for an amount of 'up to and including my life.' That is Honor, and there are way too many people in this country who no longer understand that...
Old 03-04-2007, 04:48 PM   #4 (permalink)
sudden urge's Avatar
Re: Squeky belt
Never spray WD-40 or belt dressing on the sepentine belt. If you want to make sure if the the belt is causing the noise, just spray some water on it as it is running. If the noise goes away, replace the belt. Your belt probably got contaminated with antifreeze and that will cause it to slip and make strange noises, even a clattering noise. Once the belt slips and gets glazed, you have to replace it.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune +2 timing. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
Old 03-04-2007, 05:42 PM   #5 (permalink)
StuntDriver06's Avatar
Re: Squeky belt
belt is where id start, not too hard and inexpensive...
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
putting on that seat belt rooster Titan General Discussion 17 03-24-2006 12:47 PM
Seat belt DGTitan Titan General Discussion 2 07-29-2005 05:59 AM
Squeky noise from rear shock PA Titan Titan General Discussion 7 01-14-2005 04:31 PM
Do you need a new Serpentine Belt? Automan Titan FAQ & Howto Area 1 12-10-2004 08:38 PM
Seat Belt Recall mitch Titan General Discussion 6 11-16-2004 06:25 AM
