Old 03-13-2007, 09:39 AM   #1 (permalink)
NismoTitan's Avatar
Urgent Please Read
I just had installed HID headlights this morning. So I went to work and now when I tried to start it turned the engine. But I guess I cut it just before it supposed to start. So I tried second time. I turn the key - nothing happens. There is no sound of the starter.
Now everything else works, but the headlights and LEDs. Back lights dont work. Only emergency lights work + everything else inside the cabin lights up, but not outside.
So I\m stuck here =(
NISMO TITAN PROJECT
2006 Titan CC SE Radiant Silver 4x4
PERFORMANCE:
- Nismo Cold Air Intake
- Flowmaster 40 dual exhaust
- 2* Advanced Timing
- Nismo Voltage Stabilizer
- Poweraid TBS
BODY:
- Front Billet grill
- Solid Painted LEER Bed Cover with Tail Spoiler
- Silverline Stainless Exhaust Tips
- Nerf Bars
- Drop Shackles
LIGHTS:
- Black Halo LED Projector Headlights
- Alpha Style 5800K HIDs with Phillips Bulbs
- Black Altezza Taillights
- Rockfort Forsgate LE Sound System
- Second set of LED fog lights
- LED accent lights
SOON (NISMO MATCHING):
- Enkei 20" RT6 rims with Nismo Stickers
- g-Force T/A KDW (New Tread) Wheels.
NismoTitan is offline   Reply With Quote
Old 03-13-2007, 09:54 AM   #2 (permalink)
vipzach's Avatar
Re: Urgent Please Read
First thing I would do would be to unplug the HID's and check all the fuses.
vipzach is offline   Reply With Quote
Old 03-13-2007, 10:08 AM   #3 (permalink)
How is the voltage stabilizer connected? Does it have a low voltage cutoff?
Old 03-13-2007, 10:15 AM   #4 (permalink)
NismoTitan's Avatar
The stabilizer is not installed right now. So I have it just lying. Havent had time to do it.
The fuses seam to be ok at the first glance. What should I be looking for?
Why is it not even cranking?
NISMO TITAN PROJECT
PERFORMANCE:
- Poweraid TBS
BODY:
- Nerf Bars
- Drop Shackles
LIGHTS:
- LED accent lights
Old 03-13-2007, 11:00 AM   #5 (permalink)
vipzach's Avatar
Are you even getting a click or the attempt of it turning over? If you don't have a volt meter, what is the alt gauge showing for voltage?
Old 03-13-2007, 11:09 AM   #6 (permalink)
NismoTitan's Avatar
gauges do have light comming up (the one when you turn headlights) But nothing like, battery abs 4wd lights are not lighting up . When I turn the key - nothing happens. When I turn on the lights - I just get the light in the cabin. And also no clicks or nothing. The battery seams to be good, so it can be a fuse. How can I check?
NISMO TITAN PROJECT
PERFORMANCE:
- Poweraid TBS
BODY:
- Nerf Bars
- Drop Shackles
LIGHTS:
- LED accent lights
Old 03-13-2007, 11:25 AM   #7 (permalink)
The fuse to the starter relay is one of the big ones on the thing that hangs off the positive battery post.
There are more fuses in the two boxes under the hood behind the battery.
Old 03-13-2007, 11:31 AM   #8 (permalink)
rooster's Avatar
If you disconnected the battery when installing the HIDs,
you might have a weak/loose connection on the battery post.
rooster is offline   Reply With Quote
Old 03-13-2007, 12:57 PM   #9 (permalink)
NismoTitan's Avatar
okey it was a big fuse on the batery. Not where it has four, but lonely one that is near the battery attachment! Now my truck requires a screwdriver to start =)
Now another thing is that in Halo head lights there are 3 LEDs on one there is only one working. And on two others there are two working and another one is almost not working. It blinks and is very dim.
Now how do I avoid this happening again? should I choose a bigger fuse for the starter, or what?
NISMO TITAN PROJECT
PERFORMANCE:
- Poweraid TBS
BODY:
- Nerf Bars
- Drop Shackles
LIGHTS:
- LED accent lights
Old 03-13-2007, 01:21 PM   #10 (permalink)
chunko's Avatar
No no no...don't use a bigger fuse. You seem to have a wiring problem or a faulty electronic device if it blew that bad boy...
The added draw of a few leds should not blow a fuse...
2005 CC 4x4 SE
AKA
TreeHuggingHippieWhore
"What if we picked the wrong religion? Every week we're just making God madder and madder." - Homer Simpson
chunko is offline   Reply With Quote
Old 03-13-2007, 01:31 PM   #11 (permalink)
StuntDriver06's Avatar
remove headlights and start over... and pay close attention to your wiring.... something isnt right.... never use a bigger fuse either... could cause a fire...
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Old 03-14-2007, 03:30 AM   #12 (permalink)
NismoTitan's Avatar
Okey. I am going to the place which installed HIDs. Seams like they are just plain stupid. What do you connect ballasts with? I would rather check it my self they do everything right this time
NISMO TITAN PROJECT
PERFORMANCE:
- Poweraid TBS
BODY:
- Nerf Bars
- Drop Shackles
LIGHTS:
- LED accent lights
URGENT - Please help! Need OEM Harness -Will Replace RedHotTitan Titan General Discussion 1 10-25-2006 11:00 PM
Need Audio help urgent... K-MU Titan Visual & Audio Discussion 7 04-10-2006 07:31 PM
Urgent Urgent Urgent!!!!!!!!!!! TitanCOP Titan General Discussion 27 06-15-2005 05:44 AM
URGENT !!! Truck Down Need Help neworleansmike Titan Suspension 7 04-08-2005 09:29 AM
Urgent, Going to the dealer to pick up Titan... Kmu Titan General Discussion 5 11-16-2004 12:08 PM
