Old 03-14-2007, 10:27 AM   #1 (permalink)
Yellomantis's Avatar
Question E85?
Did Nissan make the Titan in a "flex fuel" capable of using e85? What is the difference in fuel systems between E85 equipped and normal? I am considering looking into a conversion to run E85 for when it comes out here to Cali.
Through some research, I have read that it has a naturally higher octane rating compared to the chitty (91) fuel we get here in Cali. therefore, when I go s/c, I can run a little more boost than the next guy.
Is it even possible to retrofit a non E85 equipped Titan to tun E85?
www.myspace.com/yellomantis
Old 03-14-2007, 11:14 AM   #2 (permalink)
baseballfanz's Avatar
Re: E85?
They started making FFV Titan in 05. Not all are FFV, I don't think they're avaiable in CA. To convert would cost too much and not justified the saving cost. Last I check maybe about $2500 to $3000. You will not get as much milage using E85 compare to dino gasoline.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 03-14-2007, 11:17 AM   #3 (permalink)
CVTITAN's Avatar
Re: E85?
I thought i read somewhere that the only difference between the FFV ready trucks was a fuel line or something?
BIG WHITE TRUCK...
CVTITAN is offline   Reply With Quote
Old 03-14-2007, 11:25 AM   #4 (permalink)
Boomer135's Avatar
Re: E85?
it may be cheaper in some states up to .50 but look what you'll get for MPG it's horrible fo long trips and ends up being a bit cheaper on long trips but you will stop to fill up more....
Boomer135 is offline   Reply With Quote
Old 03-14-2007, 11:37 AM   #5 (permalink)
vipzach's Avatar
Re: E85?
Since you have an 2006, you may have a FFV, it should say on the gas door and under the hood somewhere.
vipzach is offline   Reply With Quote
Old 03-14-2007, 11:58 AM   #6 (permalink)
Maverick_Titan's Avatar
Send a message via Yahoo to Maverick_Titan
Re: E85?
yeah .. per tank .. i had a roughly 2 to 3 mile per gallon difference when it came to usin E85 over Gas...yeah gas is more expensive but, per tank .. you definitely get more miles..no scientific testing here.. just divide the miles you got by the # of gallons ya just put in ..
chris
black 05 XE CC/ Magnaflow single in dual out/ S&B CAI - Helix TBS/ *2 Advance/ TB Coolant Bypass mod /Midland CB w/ twin 3' whips / full upper n' lower billet grill/ Valor DTS-605w 6.5'' din am/fm/cd/dvd and XOvision 11'' flip down/ 2- 12'' Memphis 15-PR12D4 Subs/ Crunch Powerzone PZi 150.2 1000w amp/ custom CSO DF sub box / Magellan Roadmate 2000 GPS/ Cobra radar detector
future mods: UpRev (read too many good things about it..gotta do it.. need cash), maybe a slight drop, alarm w/ auto start, rims n' tires if i can get em' (again.. need cash) ..
Maverick_Titan is offline   Reply With Quote
Old 03-14-2007, 12:23 PM   #7 (permalink)
titanical's Avatar
Re: E85?
im not sure but im willing to bet theres no conversion to change over to both e-85 and petroleum distilate..... good luck though!
pure macaroni!
titanical is offline   Reply With Quote
Old 03-14-2007, 12:27 PM   #8 (permalink)
Re: E85?
As far as I can tell, I at least have to swap out the fuel lines and possibly the injectors.
The main reason I am considering the conversion is for the higher octane. More boost.
Old 03-14-2007, 12:33 PM   #9 (permalink)
vipzach's Avatar
Re: E85?
This is the first one I found on a quick google search.
http://flextek.com/
Old 03-14-2007, 01:19 PM   #10 (permalink)
titanical's Avatar
Re: E85?
http://flextek.com/
damn that is cool as sh!t!....... ok well im man enough to admit when im wrong.....lol
pure macaroni!
Old 03-14-2007, 01:44 PM   #11 (permalink)
Re: E85?
All 06 and up are E85 capable!
earl1z19 is offline   Reply With Quote
Old 03-14-2007, 01:54 PM   #12 (permalink)
Re: E85?
I would have to talk to my dealer first. Don't want to take the chance. I don't have the sticker in the fuel door that says it's e85 compatable...
Old 03-14-2007, 03:21 PM   #13 (permalink)
Duner49's Avatar
Re: E85?
Here is some info I found on E85 and conversions. Hope this answers some questions.
http://encycl.opentopia.com/term/E85
2006 KC SE 4x4 Big Tow and Off Road Pkg
Under The Hood: Volant CAI, Banks Monster exhaust, Prestige Remote Start
Suspension: 7" CST lift, DR Front Coilovers, Fox Res Rear, AIR Lift leveling bags.
For Sale: 20" MB Wheels, 305/55 Nitto Terra Grappler
Interior: 2-12" Pioneer Subs in custom glass and wood encloser. 1200 watt Lanzer amp, Prodigy Brake Controller
2005 Raptor 660
2003 Yamaha R1 - R.I.P.
Duner49 is offline   Reply With Quote
Old 03-14-2007, 03:42 PM   #14 (permalink)
Shane06fl's Avatar
Re: E85?
I should say FFV on your hood sticker also. I have one 2005 Titan that was made in 3/05 that is not FFV and the Other 2005 is FFV and it was made in 8/05.
Don't know the exacts of the conversion but on Discovery chanel they were running a show about future cars and they said to convert a car to be able to run E85 would be about $150-$200, would need to changed out the fuel line and another part. The ECU should pick up the difference in fuel and adjust accordingly.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC SE
Big Tow
4x4
Silver
Old 03-14-2007, 06:50 PM   #15 (permalink)
Re: E85?
That special is what got me thinking about it.
