My baby broke =(
Okey so after unsuccesfull installation of HIDs (main 140amp fuse on the batery broke) I have so many things not working. Basically, while I was searching for a fuse I lost 40amp fuse from ABS - hence - speedo, abs are not working, + I have 4wd, abs, break lights ON =( So I got to the service to put the bew fuse back one. They replaced the battery attachment with fuse and put new ABS fuse. But those lights dont go off and speedo not working as well. If I turn HIDs on (this is not sure. probably with them off as well) I loose power in the engine for a second. It look like this - you drive normally at about 2.500 rpm, and then it just goes down till idle for a sec. It can do that for several times in a row.
Services in Russia SUCK big time. So I dont what to do =( Services would probalby just replace everything that has to do with lights that are on my dash. This happened to me. I had an unplugged cable going from the steering - they replaced horn, and cruise control instead of plugging the cable. GOOD that I was during an installation and stopped them right there (so I didnt have to pay anything and they kept parts they've ordered.
But basically I am in PANIC. I have replaced fuses and everything is still like it was before =(
Now I drive VW beetle and damn ... after BT mirrors I cant see dang and it just feels really weird =((
HELP!!!
I am going to uninstall HIDs this weekend - hopefully this will solve at least something. It seams like I dont get enough power - not on LED light up in the headlight + I only have one highbeam comming on =(
NISMO TITAN PROJECT
2006 Titan CC SE Radiant Silver 4x4
PERFORMANCE:
- Nismo Cold Air Intake
- Flowmaster 40 dual exhaust
- 2* Advanced Timing
- Nismo Voltage Stabilizer
- Poweraid TBS
BODY:
- Front Billet grill
- Solid Painted LEER Bed Cover with Tail Spoiler
- Silverline Stainless Exhaust Tips
- Nerf Bars
- Drop Shackles
LIGHTS:
- Black Halo LED Projector Headlights
- Alpha Style 5800K HIDs with Phillips Bulbs
- Black Altezza Taillights
- Rockfort Forsgate LE Sound System
- Second set of LED fog lights
- LED accent lights
SOON (NISMO MATCHING):
- Enkei 20" RT6 rims with Nismo Stickers
- g-Force T/A KDW (New Tread) Wheels.
