Originally Posted by christo
well i can't find the programming instructions on here, and I did search (came up with 249 results). all of teh ones on ebay say that they are for 04-06 models, they have the same part number - will these work with an 07?
Programming instructions are the same no matter what Nissan vehicle you get into.
1. Get in the vehicle,
2. Insert and remove your key in the ignition in rapid succession several times, anywhere between 6 and 12 times, until your hazard lights flash,
3. Turn your key to the ACC position (after hazard lights flash),
4. Press the LOCK button on the key fob,
5. Turn your key to OFF position,
6. Remove key from ignition,
7. Press unlock button on key fob to test,
8. Repeat same procedure for all other key fobs.
