Old 03-17-2007, 09:03 PM   #1 (permalink)
titan2005's Avatar
Got me a 2007 Titan
just got me a 2007 Titan XE CC 4x4 Smoke with power doorlocks and windows but it does'nt have keyless entry ? what will i have to do to get keyless entry ? (paid $28450.00 OTD) is this a fair price ? anyway i bought it. Guys give me some help on the keyless entry !!!!!
titan2005 is offline   Reply With Quote
Old 03-17-2007, 09:11 PM   #2 (permalink)
Advocate07's Avatar
Send a message via AIM to Advocate07
Re: Got me a 2007 Titan
You didn't say something before you drove it home... ???
Advocate07 is offline   Reply With Quote
Old 03-17-2007, 09:16 PM   #3 (permalink)
titan14's Avatar
price seems fair. the remote keyless entry is an part of the "preferred package" option. How do you get power windows and locks with an XE? i dont see that option available on the XE
titan14 is offline   Reply With Quote
Old 03-17-2007, 09:17 PM   #4 (permalink)
titan2005's Avatar
yes but the service dept was closed and the salesman was going to give me 2 remotes but he could'nt get them programed ? so we was wondering is there something else i have got to get ? he thought you could just program them ? so he is going to ask the service guy monday. i was hopeing someone here would know
Old 03-17-2007, 09:23 PM   #5 (permalink)
Advocate07's Avatar
You'll prolly just have to wait till monday buddy..
But I dont speak for everyone here, just dont get ur hopes up lol
Old 03-17-2007, 09:25 PM   #6 (permalink)
titan2005's Avatar
it don't say preferred package on the sticker but it has PDL, PW, Power sliding rear glass, cruise control. i know what you're saying but i'm puzzled about having pdl and no keyless entry ?
Old 03-17-2007, 09:30 PM   #7 (permalink)
Kronos1965's Avatar
First off, Welcome to Titan Talk.
You have to make sure your Titan does have keyless entry before you can make it work.
ID CODE ENTRY PRODCEDURE
Step 1) Sit in drivers seat, close and lock all doors.
Step 2) Insert key into and remove it from ignition key cylinder more than six times within 10 seconds.
(Hazard warning lamps will then flash twice).
NOTE:
Withdraw key completely from ignition key cylinder each time.
If procedure is performed too fast, system will not enter registration mode.
Step 3) Insert key into ignition key cylinder and turn to ACC position.
Step 4) Push any button on remote controller once. (Hazard warning lamps will then flash twice).
At this time, the oldest ID code is erased and the new ID code is entered.
Step 5) Do you want to enter any additional remote controller ID codes?
A maximum of four ID codes may be entered. If more then four ID codes are entered,
the oldest ID code will be erased.
If you do not want to enter any additional remote controller ID codes, go to Step 9).
Step 6) ADDITIONAL ID CODE ENTRY
Lock all doors with LH (driver side) lock/unlock switch
(in main power window and door lock/unlock switch).
Step 7) Push any button twice on remote controller once, (Hazard warning lamps will then flash twice).
Step 8) Do you want to enter any additional remote controller ID codes?
If so, unlock doors then repeat Step 6) and Step 7).
Step 9) When complete, open door, and check operation of remote.
Kronos1965 is offline   Reply With Quote
Old 03-17-2007, 10:31 PM   #8 (permalink)
Exclamation Re: Got me a 2007 Titan
titan2005 while im sure you will disagree it sounds like you are dangerously close to an aftermarket sitation. While PWR Widows and door locks would make it appear factory....BEWARE....I only mention this 'cause it was there when you test drove it then dissappeared when you refused it. you cant refuse factory options on a vehicle already built!!!! Well good luck and let us all know how it turns out....
Floating-Traction is offline   Reply With Quote
Old 03-17-2007, 10:57 PM   #9 (permalink)
baggettp's Avatar
Not positive here, but seems to me if you got everything power, it should have the keyless entry? Either way congrats.
baggettp is offline   Reply With Quote
Old 03-18-2007, 01:25 AM   #10 (permalink)
Rick Guess's Avatar
um PDL does not mean keyless it is a modual they have to put in if im not mistaken
also how did you get power with a XE?
unless the dealer upgraded it, and that is not aftermarket, at least not like say a head unit, or Infinity,Jbl or some other set of speakers
it is warantied (if the dealer did it)
but my question is why didnt you just let the truck wait till Monday
lol
i would have no confidence in a salesmans word, at least not if he "had to program the fob" that tells me it doesnt have KE but i could be wrong...
2008 SE KC 4x4 Blizzard White Titan
Tow package and popular package
OEM Bug Deflector
Rick Guess is offline   Reply With Quote
Old 03-18-2007, 06:48 AM   #11 (permalink)
titan2005's Avatar
I think it's factory because the FACTORY WINDOW STICKER states power windows, power door locks, power sliding (vertical) back glass ?
Old 03-18-2007, 07:01 AM   #12 (permalink)
titan2005's Avatar
also how did you get power with a XE? Hey, Rick
it's a factory upgrade i've seen a few with this it's called preferred package ! BUT mine does'nt say preferred package but it has a lot of the things that come with a preferred package ? i thought i was getting the preferred package after seeing the power options on the truck, i'm a little puzzled. i was just sure it had keyless entry with it already having pdl ? i guess i should have checked closer. i'm sorta dissappointed
do you have a few days to back out of the deal ? if so i'm considering it, so i can be sure and get the keyless entry ! i've not even got the money yet i'm going to the credit union tomorrow they just pulled my credit and i told them the secu had a better rate so they based it on that but i told them i've never borrowed any money from secu but they INSISTED i would have no problems getting the money ! i paid them $3000.00 down and going to borrow $25450.00 from secu. SO BEING I DON'T HAVE THE ACTUAL LOAN YET CAN I BACK OUT ?
Old 03-18-2007, 07:13 AM   #13 (permalink)
niceun's Avatar
First, congrats. Next, the XE CC comes standard with PW and PDL. The preferred pack. includes keyless, 6 disc cd and a couple other things. If your truck does not have the Pref.pack., i'm sure you can still add the factory remotes. I know, it doesn't make sense, power locks without standard remotes....My '04 XE CC had the pref pack, and it was a must. Hope this helps.
'07 Toyota FJ Cruiser 2wd Black Cherry Pearl
Gone-'05 LE Crew Cab.4x4.Red Brawn.Graphite/Titanium Leather.OR.Loaded.Born 2/05.Firestone Destination ATs.Currently 27k miles....
Gone-'04 XE Crew Cab.4x4.Radiant Silver.bought 3/04-traded 1/07...
niceun is offline   Reply With Quote
Old 03-18-2007, 07:35 AM   #14 (permalink)
titanical's Avatar
i also wondered the same thing, how does an xe have power options? i have been looking at a crew cab xe at our dealer that has every option as my se, plus 4wd. the only difference between my se and the xe on the lot is the gray steel wheels...
pure macaroni!
titanical is offline   Reply With Quote
Old 03-18-2007, 10:01 AM   #15 (permalink)
Rick Guess's Avatar
i dont see why you cant add them (have them do it)
but make it part of the deal
even if you gotta pony up more money down
that way you get the warranty
i cant wait to get mine in the mud or movething
OEM Bug Deflector
2007 Titan ? titan2005 Titan General Discussion 15 03-23-2007 10:15 PM
2007 Titan chieflikalotapus Titan General Discussion 10 12-16-2006 09:10 PM
2007 Titan HP? Stomper4x4 Titan Performance Modifications 15 12-02-2006 09:57 AM
?'s about 2007 Titan Zod Titan General Discussion 8 07-17-2006 07:59 AM
2007 Titan AgTitan06 Titan General Discussion 35 01-06-2006 11:25 AM
