I went searching and couldn't find the answers, so...
1. where is the Titan made/assembled?
2. does the 5.6 have a timing belt or chain? if belt, what the change interval?
thanks so much, I've been reading a lot here the last few days, and really appreciate all the info!
1- MS
2- I think its a chain?, not sure about interval
The Titan is is made in Canton, MS 39046. The engine has a timing chain, which if you keep your oil changed regularly you will probably never have to ever touch it. The engine is made in Dechard, TN. The trans. is made by JATCO I think in Japan, not sure. The frame is made by Tower Industries, down the road from the plant. The axels are made by Dana. The brakes are made by Bosch. The exhaust is made by Calsonic in several different areas in MS, TN, and other areas.
COOL! you guys rock!
the Titan is more American than a Silverado! I'm glad about the chain, too. the only Nissan engines I was familiar w/ was the 3.0 in the hardbody and the maxima, used to be a 60K interval on the belt. so, thanks, I'm liking the Titan more and more!
if it's a chain, you'll never need to change it.
Chains don't wear like belts do.
I had a chain wear to the point of becoming loose on a Toyota 22R engine. It jumped a tooth. I was lucky and it didn't cause any major damage. I had to have the chain and the gears replaced. So no, they don't wear like belts, but they do wear.
A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America' for an amount of 'up to and including my life.' That is Honor, and there are way too many people in this country who no longer understand that...
You almost have to pour sand in the crankcase of a 22R to kill it! One of the things that Toyota did right.
SOLD THE TRUCK!
TITAN OWNER NO MORE!
Born 02/07 - Snagged 02/17/07 KC SE - Red Alert - 18" Helo 835 Chromes - BFG 285-65-18 AT KOs - 2.5 Front NCD kit - Tint - SS Billet - Pendaliner -
