Would something like this work to roll up the windows?
http://www.partsexpress.com/pe/showd...number=330-125 I know you can buy the thing from kptechnologies, but I would like to hit the lock button on my remote once, lock the doors and up go the windows.
Sometime I am going to add a remote, but would like to know if this would work with our factory alarm. I am guessing it works off a +/- signal. If it does, there should be an easy way to make it work.
My thinking is that if it works from either a + or - momentary signal, it would work. Depending what our locks work from, you could use a relay to supply the power.
Am I in left field on this one?
