Old 04-01-2007, 02:15 PM   #1 (permalink)
Old Speed's Avatar
Trailer Brake, Signal Light fuse Help?!?
I poped a fuse for the trailer lights. i figured out the running lights fuse and i just cant find what fuse the left/right and brake lights fuse that go to the 7 pin connector. Every thing else works except that.
Thanks hopefully some one will know soon.
05, Smoke titan, SE, king cab,w/ big tow pakage
Old Speed is offline   Reply With Quote
Old 04-01-2007, 05:19 PM   #2 (permalink)
TallTexan's Avatar
Re: Trailer Brake, Signal Light fuse Help?!?
I found a 15 amp fuse under the hood on the left side fuse box. It was blown and I had no trailer lights. It is hard to find but read the box for fuse description and you will see it.
Robert Louis Stevenson
Old 04-01-2007, 05:43 PM   #3 (permalink)
Old Speed's Avatar
got it. it was the fuses under the driver dash 2 10 amp fuses.
Old 04-11-2007, 11:39 PM   #4 (permalink)
Are the fuses in a certain location? I have a 04 Titan and my Right side turn signal and brake light is not working everything else is. I tested the plug on the truck and I am not getting any power to the right side brake and turn connector
Thanks,
Randy
rtfulk is offline   Reply With Quote
trailer taillights fuse location k94max Titan Problems & Dealer Service 3 09-03-2008 05:33 PM
Trailer Left Turn Signal/left brake light not working bclmread Titan Towing & Hauling 60 04-06-2008 06:43 AM
Keep Blowing Fuse hooking up trailer BSIMPSON Titan General Discussion 2 07-26-2006 08:32 AM
Fuse for Trailer Running Lights Vegas Titan Towing & Hauling 1 10-26-2005 11:43 PM
Installing Hitch and Wiring Trailer Brake Light Plug pilot4net Titan Towing & Hauling 9 10-27-2004 05:52 AM
