Old 04-03-2007, 10:03 AM   #1 (permalink)
Tire size question
Hello all!
I've got an 04 Titan with the base 17" steel wheels that are in need of a new set of tires. I'm very interested in the Bridgestone Revo's, they sound perfect for me. My problem is I'm not sure which size to get. The stock tires on my truck are: 245/75-17's. The Revos come in:
235/75
245/70
255/70
265/70
285/70
255/65
265/65
(all 17's)
Can anyone help with what size Revo would work well without rubbing, effecting handling, or looking weird?
Thanks!
Ed178 is offline   Reply With Quote
Old 04-03-2007, 10:23 AM   #2 (permalink)
Blackbeauty's Avatar
Re: Tire size question
What's on your truck now? Just go with that size if it looks ok to you. I'd probably go with the 285/70's myself.
Here's something that should help you:
Plus Sizing Calculator
Plus-sizing has become a key tool for tire dealers succeeding in the high performance tire market. Still, many dealers remain concerned about tackling plus-one, plus-two, plus-three or greater tire fitment changes.
The basic rule of thumb with plus-sizing is: the overall diameter of the new tire should not be significantly different than the overall diameter of the old tire. A significant change in overall diameter - .75-inch or more - means the vehicle’s speedometer will not be accurate, and more complicated adjustments will be required.
Many tire makers, such as Yokohama, Pirelli, Bridgestone/Firestone and others, have developed easy-to-use plus-sizing conversion charts - like the one below - that make it easy for dealers to select the proper tire and minimize impact on tire diameter and the speedometer. Here’s how to use this chart:
Using the horizontal top row of this chart, find the current tire’s aspect ratio
Using that column, go down to the current tire’s section width. This is your starting point for all Plus Sizing calculations using this chart.
Section widths along the same horizontal row, including their corresponding aspect ratios, are the Plus Zero size options and will fit the customer’s existing wheel. (This assumes that the customer’s current wheel is, in fact, the correct size. If a Plus Zero tire change is desired, consult tire/wheel fitment guides to make sure the current wheel is the correct size.)
For Plus One Size Option - From your starting point, move up one row and then to the right two columns. This will give you the correct section width and aspect ratio for a Plus One fitment. Example: If your starting point is a 60-series tire with a section width of 225, the correct Plus One Option is a 50-series tire with a section width of 235.
For Plus Two Size Option - From your starting point, move up two rows and then to the right four columns. This will give you the correct section width and aspect ratio for a Plus Two fitment. Example: Current tire is a 60-series with a 225 section width, then the Plus Two Option is a 40-series tire with a 245 section width.
For a Plus Three Size Option - Again using your starting point, move up three rows, then move to the right six columns. This will give you the correct section width and aspect ratio for a Plus Three fitment. Example: Current tire is a 75-series with a 205 section width, then the Plus Three Option is a 45-series tire with a 235 section width.
Once the Plus Sizing Option is selected, check the load carrying capacity of the selected tire size to make sure it is equal to or greater than the current tire.
If the Plus Size Option does not have adequate load carrying capacity, it may be necessary to either reduce the amount of plus sizing (if the lesser tire provides adequate load capacity) or increase the Plus Size Tire Option by 10mm to achieve the proper load carrying capacity.
Consult your manufacturer’s tire fitment guide or databook for load carrying capacities and other related details.
Warning: Any Plus Sizing tire fitment change requires a new wheel in the correct size for that particular new tire size
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 04-03-2007, 10:31 AM   #3 (permalink)
After re-reading my initial post, I should have said that the Revo's don't come in the same size of my current stock tires. Would the size you mentioned have any drawbacks in terms of handling, rubbing, etc? Thanks for the informative post, that's good info.
Old 04-03-2007, 10:35 AM   #4 (permalink)
So if I'm reading the chart right for roughly the same size tire:
My stock: 245/75
would be close to a: 255/70
Old 04-03-2007, 10:36 AM   #5 (permalink)
There shouldn't be any issues with that size. If you have the leveling kit, definitely no problems. If you have concerns, go with the 265/70's Just slightly larger than your current tires. 10 mm isn't that much wider. Heck, I had 265's on my Ford 4x4 with no issues. No doubt they'll fit this truck.
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 04-03-2007, 10:37 AM   #6 (permalink)
My stock: 245/75
Right. So the 265's are just slightly wider.
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 04-03-2007, 11:59 AM   #7 (permalink)
My stock: 245/75
here is an attachment with a tire size calulator. thanks
jrubin is offline   Reply With Quote
Rim & Tire Size Question... Chromematrix Titan Wheels, Tires & Brakes 21 11-03-2005 11:30 AM
Tire size question ecbmxer Titan Wheels, Tires & Brakes 2 09-26-2005 12:41 PM
Tire SIZE Question?? scubastud Titan Wheels, Tires & Brakes 0 07-04-2005 03:18 PM
Tire size question.... bossheadhoncho Titan General Discussion 7 01-11-2005 07:58 AM
Tire size question jeremyzz Titan Wheels, Tires & Brakes 1 09-02-2004 04:07 PM
