Did the first oil change today at 1,299 miles. Yes, I know that's not much mileage on the factory fill but I'm peculiar about getting any manufacturing debris out of there. Went ok but thought I would have to do the old "drive a screwdriver through the factory filter" to get it off. Finally used a strip of rubber gasket to increase the friction of the wrench. The little oil chute under the filter is a nice touch. I went with Pennzoil Platinum....in the process of changing all our vehicles over from Mobil1 since it apparently isn't what it used to be and you can get equal or better performance from some other oils for much less money. Used the recommended Nissan filter although I was disappointed that it was made in China
. I'm glad to see a drain plug on the trans pan as well.
