Old 04-14-2007, 08:32 PM   #1 (permalink)
Arrow Fastest Titan!!!!
OK All Titans have the same engine but which is fastest by build/weight? I am assuming that a regular cab will be the fastest over a KC and CC due to the excess weight. I have a 2007 CC and I am assuming it is the slowest ( buy less than a second maybe) but my big question is how should I take all the advise on tuning a Titan as far as if it works for one guy it may not have the same affect for my CC. Well I hope my question makes sense if not please ask and I will explain further.....
Floating-Traction is offline   Reply With Quote
Old 04-14-2007, 08:36 PM   #2 (permalink)
helomech's Avatar
Re: Fastest Titan!!!!
I would say that the 2X4 king cab with the tow package would be the fastest. It has the best gears and the lightest truck.
helomech is online now   Reply With Quote
Old 04-14-2007, 08:45 PM   #3 (permalink)
dawgs77's Avatar
Nissan does not make a Regular Cab Titan. Only King Cab and Quad Cab.
As for which is the fastest.....Mod for the the lightest truck would be the fastest with identical HP and TQ numbers.
So a King Cab with Big Tow should be the fastest.
BUT....My Crew Cab seems to be tops of all Titans that have run at the tracks without a tune.
So it really just depends. On a good deal of ocassions the 4X4 with the off road package seems pretty fast. This is for two reasons...one 3.36 gears...two...the Off Road 17" wheels are the lightest Nissan makes at 26.5 lbs. The XE wheel comes in at 43 I think it was.....that steelie was pretty heavy. SE wheels are in the mid 30's.
Oddly enough...the weight difference between a CC and KC is pretty close. My Crew Cab weighs 5100 lbs.
2006 SE Crew Cab, Big Tow, Traction Package, SE Popular Package...mods....yup...and they seem to work well together! UpRev Osiris now installed!
RT .079
60' 1.848
1/8 8.792
MPH 77.458
1/4 13.896
MPH 95.996
Horsepower Sells Cars, Torque Wins Races!
dawgs77 is offline   Reply With Quote
Old 04-14-2007, 10:31 PM   #4 (permalink)
goathead's Avatar
my buddy at work has a 2006 kc 4x4 w/ off road and big tow. i have a 2004 cc version of this w/ the same options.
we both have the 2* timing advance and drop in filters, no other mods. we raced on the highway from about 45-50 to 80-85. i pulled a good half truck on him. not running, just walking. again, i have the crew cab.
steve
Old 04-15-2007, 09:05 AM   #5 (permalink)
drse's Avatar
All models of the Titan have a speed limiter which limits top speed to around 112 mph. So one Titan can't be faster than another...
drse is offline   Reply With Quote
Old 04-15-2007, 09:29 AM   #6 (permalink)
dawgs77's Avatar
But one can get there before the other. The speed limiter is 114.
RT .079
60' 1.848
1/8 8.792
MPH 77.458
1/4 13.896
MPH 95.996
Old 04-15-2007, 09:42 AM   #7 (permalink)
tnbowhunter's Avatar
No two engines will be the same. If your lucky you will get one of the "fast" engines, if not you will get a "slow" one. Theoretically a KC with it's lighter weight should be the fastest, and it may very well be "on average" but again it's all the luck of the draw.
2001 Polaris Sportsman 500.
Old 04-15-2007, 11:47 AM   #8 (permalink)
CHEIF's Avatar
Good info, I was always wondering about the weight on different wheels. I just switched from the stock 285 to a 265 tire. It's about 1.5" less dia and 4 lbs lighter. There is a very big difference I can feel, although I haven't raced anyone with them. I think it has more to do with the weight than the dia in this case.
Another consideration is the exhausts. Wasn't it either the CC or the 4x4 that had an extra set of resonators up front? I thought they were mini-cats that heat up quickly. Also with the '07's being more of a dual exhast.
'04 TITAN CC XE 4X4
OFFROAD PKG
PREFERRED PKG
SILVER
CHEIF is offline   Reply With Quote
Old 04-15-2007, 02:26 PM   #9 (permalink)
Arachnid's Avatar
By "slow" I'm assuming you are referring the the Monday moning engines where they are recovering from the Tennessee bourbon weekend.
Arachnid is offline   Reply With Quote
Old 04-15-2007, 04:42 PM   #10 (permalink)
budhound's Avatar
Not to sure about the speed limiter being at 112 or 114. In my 05 I had it around 120 several times. I haven't tried it in my 07 yet.
'07 Titan LE CC / Radiat Silver
Purchased 4/12/2007
Sirius / Sylvania Silver Star Heads and Fogs / Lund Stainless Steel Bug Shield/MB Senna Chrome 20's / General 285/50/R20's / Keypad Entry
2* timing advance 4/14/2007
Volant CAI and Exhaust coming soon
budhound is offline   Reply With Quote
Old 04-15-2007, 04:43 PM   #11 (permalink)
StuntDriver06's Avatar
112 is all i can get in mine... was 110... maybe the fuel is just cut back to a preset point and however your truck handles it is where it stops pulling??
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Fastest vehicle the TITAN can beat. IlovemyTitan War Stories 46 11-15-2007 05:33 PM
Fastest Titan? BlckTitan05 Titan General Discussion 54 03-07-2007 06:04 PM
Fastest you have gone Camy1448 Titan Performance Modifications 127 01-07-2007 08:47 PM
fastest banks ever afplayboy18 Titan Performance Modifications 24 08-11-2006 09:57 PM
