Old 05-03-2007, 08:38 PM   #1 (permalink)
bum76's Avatar
Send a message via Yahoo to bum76
wireing harnes recall
is this worth bringing in
2004 NISSAN TITAN SE KING CAB 4X4
American Racing MACE chrome rims17x8.5"
BF Goodrich All Terrain T/A 305/65/ R17
MAAP STAINLESS STEEL NERF BARS
LUND MOON VISER2
BUG DEFLECTOR
AIRAID COLD AIR INTAKE
GIBSON DUAL EXHAUST
2.5" FRONT LEVELING KIT FROM TOP GUNZ CUSTOMS AND 1.5" BLOCK AND U-BOLTS IN REAR
TRUXEDO LO-PRO TONNEAU COVER
LUND STAINLESS COLD FRONT GRILLE
HUSKY FLOOR LINERS
BUDDY CHRIST DASBOARD ACCESSORY
(TRUCKNUTZ)
JACK AND THE BOX ANTENNA BALL
AND AN 8-BALL SHIFTER FROM HOTRODGIRL ON EBAY.
here is myspace page
http://www.myspace.com/138535049
bum76 is offline   Reply With Quote
Old 05-03-2007, 08:59 PM   #2 (permalink)
Supporting Vendor
P's Titan's Avatar
Re: wireing harnes recall
its up to you. Dealer will determine if work is really needed. I recall seeing one person say the new cover sucks because of the noise it makes.
Old 05-03-2007, 10:19 PM   #3 (permalink)
sudden urge's Avatar
The new cover is fine and quiet. Do not hesitate, and get it done before they have to gut the interior.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune in FST. Currently running the Superchips Flashpaq. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
Old 05-04-2007, 06:05 AM   #4 (permalink)
thclimer's Avatar
I would have to agree, having it done now is better than the consequences latter. I had mine done about 3 weeks ago and haven’t noticed anything different with noise and function. I read the TSB about what must be done if they need to replace the harness and your truck definitely gets all torn apart inside. Even with the most conscientious mechanic I would have to wonder how it would all go back together like it was done at the factory.
2006 LE KC 4X4 BT, Radiant Silver
Prodigy Brake Controller
Equalizer Hitch
Scan Gauge II
Firestone Air Springs
Bridgestone Dueler A/T Revo's
A.R.E. Z-Series Cap
thclimer is offline   Reply With Quote
Old 05-04-2007, 06:08 AM   #5 (permalink)
ProjectTitan007's Avatar
What years are affected ?
2007 Silver Titan CC SE w/ Popular Package.
2006 Suzuki C50 Blue/Gray
Chrome Altezza Tailights, Fog light Kit, SS Gauges, ARE LowPro 2* advance , Magnaflow 12588 and a K&N. Not bad for a start. Oh and an interior that's a bi*ch to keep clean.
ProjectTitan007 is offline   Reply With Quote
Old 05-04-2007, 08:37 AM   #6 (permalink)
thclimer's Avatar
Its only the King Cab because the rear doors open so far. 2004-2006 Go to:
http://www.nissanhelp.com/Recalls/Ti...20Cab/2006.htm
to see a PDF of the recall notice with serial numbers of effected Titans.
Equalizer Hitch
Scan Gauge II
A.R.E. Z-Series Cap
Old 05-04-2007, 05:56 PM   #7 (permalink)
I'm going to fix it myself - can't give up the truck on a weekday and all they have on Saturday is oil-change drones that aren't allowed anywhere near my Titan!
duck_man is offline   Reply With Quote
Old 05-06-2007, 07:00 AM   #8 (permalink)
It looks like crap. First , I don't think the dealer techs even looked at the TSB. Someone had posted the TSB on this forum a few months ago, so I knew what to look for. The dumb a$$es did not place the cover as described in the TSB, did a lousy taping job and left exposed wires where the harness enters the body. In addition they placed the harness plastic support in the wrong place. I should have just done it myself and saved the aggravation and wasted time.
2006 KC, SE 4X4, BT
2004 Infiniti G35 Coupe, 6MT
Mr.TEE is offline   Reply With Quote
Old 05-07-2007, 06:31 AM   #9 (permalink)
Triple S's Avatar
Considering how the defect could case the seat belt pretensioners to not work, as in key components of the crash safety system, I can't believe someone would contemplate if it is worth getting this looked at by a dealer or not. And for those going to "fix" it themselves, I sure as heck hope you test all the wires for continuity, because just making the outer wrap stronger is a case of treating the systems and not the cause.
It's a recall, get it done!
I'm sick and tired of all the problems...
Triple S is offline   Reply With Quote
Old 05-07-2007, 08:57 AM   #10 (permalink)
mjw357's Avatar
wiring harness recall
The procedure is only done if the protective wrap is worn through a certain amount. If there is no sign of chafing on the wrap, there is nothing to be concerned about.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
mjw357 is online now   Reply With Quote
Old 05-07-2007, 09:04 AM   #11 (permalink)
vipzach's Avatar
Re: wiring harness recall
I think you are wrong. If there is damage to the wires, they have to remove the entire back half of your interior to replace it. If no damage is present, they install a new and stronger cover.
vipzach is offline   Reply With Quote
Old 05-07-2007, 10:18 AM   #12 (permalink)
mjw357's Avatar
I looked at it again, you are correct.
Old 05-07-2007, 10:28 AM   #13 (permalink)
Justintoxicated's Avatar
Yea mine squeeks a bit now when I open and close the rear doors, not that bad though... The new harness kind of binds up and folds up when I open and close the doors now, kind of gets pinched in the door. I'm not certain it is any better than it was before the recall was done, it seems to be worse now, but with better casing...
Is there a new recall? TOK Titan General Discussion 8 12-13-2006 07:00 PM
Wireing pigtail quick89 Titan Towing & Hauling 1 10-19-2006 04:22 PM
Electrical Question ... Hi Beam Wireing Problem SHOTGUN Titan Performance Modifications 3 09-24-2006 12:09 AM
Question on Head Light Hi Beam Wireing Problem SHOTGUN Titan Problems & Dealer Service 1 09-22-2006 05:23 PM
Trailer wireing question divein6 Titan Towing & Hauling 7 09-20-2004 05:34 PM
