Re: where can i get the software for the 2 degree timing advance?
Originally Posted by sbones
new member here, what will the 2* advance do to the performance?
Give you a little more power down low and off the line. it will still fall under factory specs if checked out. most titans come from the factory a either 15 or 16* at idle. so your jusst moving it up 2 degrees. Manual says anything +5/-5 of 15* is good
