Old 06-10-2007, 09:13 AM   #1 (permalink)
luiscaratinijr's Avatar
******* Industries???
Anybody install their cornfead Lift kit 2.5 and 1" kit?
Ive looked for instructions but not found anything or any pics or members using this kit??
Thanks
2005 Nissan Titan 2wd,
TBypass Mod, BURNOUT MOD
S&B Intake
Airaid TBS Spacer...
JBA Catback
******* Mini lift
Toyo Open Country a/t 325/60/18
luiscaratinijr is offline   Reply With Quote
Old 06-10-2007, 11:02 AM   #2 (permalink)
Demondw3's Avatar
Re: ******* Industries???
Did you try contacting Jason directly?
check out my trucks transformation.
http://www.kodakgallery.com/Slidesho...Uy=8mexzr&Ux=0
Demondw3 is offline   Reply With Quote
Old 06-10-2007, 11:32 AM   #3 (permalink)
Carbeaux's Avatar
Can't be any different to install than the PRG or NCD kits. It's just a spacer like those are. Look in this thread for info on installation.
Hook 'Em Horns!
- Frank Zappa
Old 06-10-2007, 11:38 AM   #4 (permalink)
Roadrunner's Avatar
Is the NCD leveling kit cheaper than the PRG kit?
Roadrunner is offline   Reply With Quote
Old 06-10-2007, 12:20 PM   #5 (permalink)
Clint's Avatar
Any reason the business name is all *'s?
Clint
You have two choices in life:
Old 06-10-2007, 12:24 PM   #6 (permalink)
Carbeaux's Avatar
Yes, it is.
Clint, I have no idea the history. But that is a forbidden word here. Just like ClubMayberry is.
Hook 'Em Horns!
- Frank Zappa
Old 06-10-2007, 12:30 PM   #7 (permalink)
Clint's Avatar
I must have missed class that day.
Clint
Old 06-10-2007, 01:22 PM   #8 (permalink)
AgTitan06's Avatar
The burt man kit requires a spring compressor to install the lift. I'd say go with PRG or NCD.
Old 06-10-2007, 01:25 PM   #9 (permalink)
Carbeaux's Avatar
It's just a spacer too, isn't it? The kit in this thread?
Quote from their website:
"The front leveling kit gives you 1.5" front spacers that are machined from aluminum and mount to the top of the coil spring assembly. These do not require coil compressors for install. These allow clearance for a 33" tire and level out your front end!"
Hook 'Em Horns!
- Frank Zappa
Old 06-10-2007, 06:37 PM   #10 (permalink)
Sorry did not know I could no write that here...
ANYWAYS, they have a 2.5front and 1" rear mini kit. But it saya it needs coil compresors to install.
Nobody installed them here?
Thanks
S&B Intake
JBA Catback
******* Mini lift
Old 06-11-2007, 01:15 PM   #11 (permalink)
I have the lift kit. You need coil compressors for the lift kit, but you don't need them for the leveling kit.
hemi_eater is offline   Reply With Quote
Old 06-11-2007, 01:43 PM   #12 (permalink)
4wheelpeel's Avatar
I dont know what leaveling lit I have but it was a 2 1/2in kit I got from 4wheel parts and it was apain to install. I had to compress the springs pit take out the strut then put a spacer between the spring and the top of the where the spring sits. and put a spacer where the prg one goes. after all the work it looks good and rides a little stiffer. I think if I had to do it again I would get the prg.
4wheelpeel is offline   Reply With Quote
Old 06-11-2007, 06:01 PM   #13 (permalink)
AgTitan06's Avatar
Not according to his website. It says the 2.5" front spacer/1" rear block requires a spring compressor.
Bed Rug by Wise Industries CO_Tit_Guy Titan General Discussion 3 10-09-2006 12:00 PM
******* Industries Rear Sills for Crew Cab. TitanNorth Titan Parts & Accessories 4 06-25-2006 03:37 PM
Rize industries lift kit dragonhead08 Titan Suspension 7 06-10-2005 02:43 PM
Bak industries rollbak with utilitrak MikeZ Titan Parts & Accessories 5 10-04-2004 05:33 PM
