A member asked me about my air bag compressor so I am posting pics of it mounted in the aem intake enclosure. I hope these pics help, it was the best place that I could find to mount the compressor. It stays fairly clean and dry.
It is very helpful. That is a very pro install and looks great. Are you happy with the air bags and the AEM? What differences did you see with the CAI? I have an '05 LE KC and may now install the CAI sooner rather than later.
I am very happy with both, the intake I personally didn't notice any improvement in performance but the sound is great. I have had the bags on for about 1.5 years and don't have any leaks or problems at all. I highly recommend both.
Great location, never thought of that. I bought a 50 dollar "Truck Tire Inflator" at the auto parts store. Supppossed to be twice the normal volume. Only using it to inflate tires when needed. I'd like to get rid of the plastic housing and mount just the actual compressor somewhere. I may now have the answer. Very safe location, and easy access too. Time to disassemble it now!
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
Well the air intake will arrive today and be installed by evening. Do I need to disconnect my battery. Also, where exactly did you drill through your firewall?
__________________ '05 Deep Water Blue LE KC, Big Toe, 4x4,
Nissan Tonneau, Bug Deflector, Rear Underseat Storage, Keyless Entry Keypad,
Weather Tech Floor Liners,
Escort 8500 Radar Detector,
Single Line Firestone Air Bags,
Active Tuning Ground,
AEM CAI,
Magnaflow Cat-Back,
Motorvator TBS
There is no need to disconnect the battery. I drilled up as high as I could without hitting anything important. I used a rubber grommet to protect the tube and wires going through the firewall. Let me know if there is anything else you need help with.
Thanks for all the great advice. I got the AEM CAI in and went ahead and mounted the compressor like you did. Everything looks great and works fantastic. The only problem is that I lose a little air sitting overnight so must have a small leak to find. Again, thanks a lot for all the help!!
AEM CAI,
Magnaflow Cat-Back,
Motorvator TBS
You are very welcome. Just air up the system and get a little squirt bottle with some soap and water and you should be able to find it fairly easy. It is probably one of the push in connection. I have had mine for almost 2 years and have no leaks at all.
yep those intakes are good for something, i mounted my hid ballast in it
07 TITAN CC,O/R,B/T 4X4 SE MAJESTIC BLUE
mods: fram boost air 2 cai.
8000k H.I.D's for low beams and fogs
22x11 -44offset KMC Monsters, black
325-55-22 nitto A/T
total chaos UCA
Rancho quicklift struts
prg 2.5 spacer
a lot less front fender
Hornblasters Train horn
5% over 15% tint all around
30% tint on windsheild
Glassworks fiberglass fenders and bedsides
