Old 06-13-2007, 08:00 PM   #16 (permalink)
vipzach's Avatar
Re: Parking brake...
Originally Posted by Leadsled124
thanx. The 10mm bolt cbe reached with the wheel ON?
The 10mm bolt is above the p-brake pedal. Use an open ended wrench.
vipzach is online now   Reply With Quote
Old 06-13-2007, 08:55 PM   #17 (permalink)
Banned
Exclamation Re: Parking brake...
Believe it or not, I just took the front brakes off my car for the first time since I got it. (actually, I think I put new pads on it right after I got it... 7 years ago.) Mainly to see how the dust shields were attached and remove them. I noticed that the inner wheel bearing seats against the dust shields. Did you guys keep the center part of the shield and trim it off? or remove it completely?
Also, can you get that cloth seal, or whatever it is behind the dust shield? I've never seen anything like it before.
I can't believe how good my brakes look, after 25,000 miles, dozens of autocrosses, and a couple of open track events.
They overheated at the opentrack events, even with the ducts, but the pads have so much material, they almost look new. The rotors are also in great shape... I'm tempted to just throw it back together, and hope they'll stay cooler and not fade as bad without the shields...
Naw, I'll probably upgrade the pads at least, and put on some braided lines.
I also run synthetic brake fluid.
I'd like to upgrade to the 12.19 wilwoods, but don't need the hassle... maybe this winter. Besides, I can't find anyone who can get them.
bobbyparks is offline   Reply With Quote
Old 06-14-2007, 07:51 AM   #18 (permalink)
vipzach's Avatar
How did you get a Titan 7 years ago?? Do you realize you are on a Nissan TITAN forum??
Old 06-14-2007, 08:02 AM   #19 (permalink)
s3gunner's Avatar
Upon further review...
I had an appointment at the dealer yeserday. After looking at the rear end closely we noticed the rear seal must just be starting to leak. Since it's still within the factory warranty, the dealer will be replacing the seal, and the shoes. Part of the job after replacing those parts will be adjusting the parking brake properly... Seems so far that the problem will be solved in a couple weeks....
s3gunner is offline   Reply With Quote
Old 09-13-2007, 10:07 AM   #20 (permalink)
Send a message via Yahoo to moulin6801
Have the dealer adjust your brake to 1/2 way!
My driveway is on a 25 degrees encline. I had problems using the parking brake when i bought the truck, when i took to the dealer for my first oil change, i complained about it, they adjusted it very nicelly (no charge) to the point where I just need to push it 1/2 way and it would fully lock the truck. I always do that before I put it on park, to eliminate any pressure to the clutch! This way you will not have that BIG "Cluck" sound when you shift out of Park.
I hope this helps... because i have such a big encline, on my driveway, i am expectiong to have them adjust it in the near future again.
So, don't take any crap from you Dealer. Parking brakes should work in a steep encline without having to push all the way down. If you are doing that, take it to the Dealer so they can adjust for you!
Good luck.
David
moulin6801 is offline   Reply With Quote
Old 11-10-2007, 06:57 PM   #21 (permalink)
Johnny08's Avatar
Re: Have the dealer adjust your brake to 1/2 way!
Good luck.
David
Well Said!!! and I agree completely, if your having issues with your parking break the dealer should adjust it for you (no charge, regardless if it's under warranty or not) or you could do it yourself but beware if you over adjust it you will burn the breaks; increase fuel consumption and possibly burn a rotor assembly (hopefully you would notice the smoke and smell the burning before this happens) but who knows, if adjusting yourself work in small increments until you get the e-break where you want it, good test is to life the vehicle up and rotate the wheels by hand in between adjustments (make sure you have it in neutral)
Good Luck.
--Jay
Blk on Blk 08 Titan LE - CC 4x2, Big Tow, K&N Filters, Nav, DVD, Bluetooth, Passport 9500i, TomTom 910, Extang Trifecta Tonneau Cover, OEM Nissan Bug Deflector ..... more to follow
Updated 2/5/2008 http://picasaweb.google.com/JamJar6/...ey=8nK2qMfdZ1Y
TT Gallery
Johnny08 is offline   Reply With Quote
Parking Brake Adjustment Justintoxicated Titan Wheels, Tires & Brakes 6 01-09-2007 07:39 PM
Help with parking brake adjustment Galaxian Titan Wheels, Tires & Brakes 15 03-21-2006 11:32 PM
Darn Parking Brake! MuskyHunter Titan Problems & Dealer Service 12 11-16-2005 12:00 AM
When do you set the parking brake? Gig'em Titan General Discussion 31 09-07-2004 06:23 PM
parking brake. amati5 Titan Problems & Dealer Service 9 04-19-2004 02:37 PM
