Old 06-16-2007, 07:35 PM   #1 (permalink)
Vector's Avatar
Exclamation Emergency, Need Help LED Tail Lights
Hi Guys,
I have a problem, I would post this in the tow section but I need the visibility in this thread.
I installed Altezza Gen 1 LED tail lights about 6 weeks ago, they have been just fine. I have not towed my car hauler since installing the LED tail lights. I have a car show at 4AM I need to go to tomorrow morning.
Here is the problem, I hooked the trailer up to the truck and I have no driving lights on the trailer. All of the lights on the truck work fine, but the trailer has no running lights. The trailer has loading lights that are working, the brake lights and turn signals are working, but no running lights.
I hooked my brothers Dodge Durango up to my trailer and all of the lights work just fine. The only thing that I have changed in my truck are the LED tail lights.
Any one seen this problem and know what it might be? Is there an easy fix?
2004 Titan 4X4 LE Crew Cab
K&N Gen 2 FIPK
2 degree timing advance
Nismo Pedals
Sirius Satellite Radio
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Vector is offline   Reply With Quote
Old 06-16-2007, 07:50 PM   #2 (permalink)
BuckyBadger's Avatar
Re: Emergency, Need Help LED Tail Lights
How about you fuse situation?
I don't know if the Titan has seperate fuses, like my Ranger did.
2007, 4x4,SE, Radiant Silver, BigTow, Bed Liner, Utilitrack, Utilitrack Bed Divider, Truxedo roll up, N-Fab Step bars,
6 disc changer/MP3, Capt Chairs. Michelin Cross Terrain, Born on Nov 06
FOB tailgate mod, Fog lights, Tailgate open light Mod, hard wire Garmin 7200, Hard wire back up camera Monitor, Wet Okole seat covers
2007 Forest River salem Travel Trailor 27RBLE
BuckyBadger is offline   Reply With Quote
Old 06-16-2007, 07:50 PM   #3 (permalink)
AgTitan06's Avatar
swap the stock taillights back on, and see if that fixes the problem
Old 06-16-2007, 08:05 PM   #4 (permalink)
Vector's Avatar
Yeah,
I will have to do that, but I dont have time to do it tonight I have to be up again in 5 hours to tow the car to the show. I was hoping that someone would have a quick fix that they knew about.
K&N Gen 2 FIPK
Nismo Pedals
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Old 06-16-2007, 08:19 PM   #5 (permalink)
Vector's Avatar
All fuses are good
K&N Gen 2 FIPK
Nismo Pedals
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Old 06-17-2007, 12:23 AM   #6 (permalink)
AgTitan06's Avatar
You know, my truck has had this problem too..I just realized it..
Last time I towed my camper, the running lights on the camper did not work...Everything else worked though, except the running lights. I tried it on the Jeep, and it worked fine. Anyone know of a TSB on this, because I'm betting that there is a problem here...I have the stock tails though..I'm betting a bad ground on the factory hitch wires.
Old 06-17-2007, 04:26 AM   #7 (permalink)
DRTYAZN's Avatar
I doubt the LED tails are your problem, it could be the harness, check all the connectors and wiring to make sure your wires are all hot, minus the ground. I have LED's, and wired LED bar to my trailer light harness wires with no problems, even while towing...
Radiant Silver '06 Titan SE CC 4X4 w/BT&OR w/ ATS Fender Flares
PC 6" lift w/ PRG A arms & traction bars, SAW's front/rear combo & Deaver pack
34" Nitto Terra Grappler's on 17" Helo Maxx 6's
Volant CAI, PowerAid TBS, Flowmaster 40
DECEPTICON center grill, SS Hood Deflector & Chrome Truck Nutz
DRTYAZN is offline   Reply With Quote
Old 06-17-2007, 12:48 PM   #8 (permalink)
Yellomantis's Avatar
Isn't there a TSB on the factory trailer harness?
www.myspace.com/yellomantis
Old 06-17-2007, 01:07 PM   #9 (permalink)
AgTitan06's Avatar
That's why I wanna know. I looked at Nissanhelp.com and didn't see one for my year, but I think I remember reading about this somewhere.
Anyone know?
Old 06-17-2007, 02:17 PM   #10 (permalink)
baseballfanz's Avatar
TSB for 04 and 05 only. The 06 and newer should not have this problem. this problem was address in 06 by adding another turn relay.
http://www.nissanhelp.com/Ownership/.../NTB05-086.htm
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 06-18-2007, 07:18 AM   #11 (permalink)
mire18's Avatar
The TSB does apply to some '06's including mine!! Just bring it in and they will swap it out....just in casse you didnt know there is also another set of fuses under the hood. Have you ever used this wiring adapter before to tow? I remember immediately after I bought my truck I tried to use my old adapter from my Ford and it didnt work something about the center pin having a different job?!
2006 Nissan Titan 4x4 Off-Road
6" Fabtech Lift
35" Nitto Terra Grapplers
20" Moto Metal Wheels
Magnaflow Exhaust
Ceramic tint windows
XM Radio
Grillcraft grill
Badges Removed
KC Lights
mire18 is offline   Reply With Quote
Old 06-18-2007, 01:59 PM   #12 (permalink)
Vector's Avatar
Angry Re: Emergency, Need Help LED Tail Lights
Hi Guys,
Well I pulled out the tail lights today and replaced the OEM bulbs in the sockets. Backed the truck up to the trailer and all is well, the trailer running lights work just fine with the factory lights. As soon as I plug the LED tail lights back in, the 10 amp fuse (#37) blows (thanks scr38) once the trailer is hooked up to the truck.
So I am not sure what to do now. I love the look of the tail lights, but I need all of the running lights on the trailer to work when towing.
The LED lights are the issue. Everything works just fine when factory stock. When the truck is not connected to the trailer, I dont have any issues with the LED tail lights, they work just fine, but once the trailer is plugged in, the fuse blows (#37). If I replace the fuse with a new one it just blows again. When I put a new fuse and and put the tail lights back to stock then plug in the trailer everything works just fine. BIG BUMMER!!!!!!!!
emergency-need-help-led-tail-lights-img_0378.jpg  emergency-need-help-led-tail-lights-img_0379.jpg  emergency-need-help-led-tail-lights-img_0383.jpg  emergency-need-help-led-tail-lights-img_0384.jpg  emergency-need-help-led-tail-lights-img_0385.jpg
K&N Gen 2 FIPK
Nismo Pedals
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Old 06-18-2007, 02:38 PM   #13 (permalink)
Sounded like a fuse issue to me. Do thoes LED's draw more power than the standard lights?
Old 06-18-2007, 03:00 PM   #14 (permalink)
Vector's Avatar
I dont know what they draw. But they are not compatable with the big tow package and any extra load placed on the factory electrical system. I also dont want to increase the size of the fuse because I dont know what gauge wire is connected to that circuit. I am worried that I would have wire melt down due to amperage draw. Also If its not just an issue of power draw, I would be worried about damage to the LED lights with an increase in fuse size.
K&N Gen 2 FIPK
Nismo Pedals
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Old 06-18-2007, 03:27 PM   #15 (permalink)
Vector's Avatar
Yes, had that replaced about a year ago.
K&N Gen 2 FIPK
Nismo Pedals
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
