Re: Need help identifying Leak
Here is a quick discription of the system, if you have the service manual it's on page EC-612.
ON BOARD REFUELING VAPOR RECOVERY (ORVR)
From the beginning of refueling, the air and vapor inside the fuel tank go through refueling EVAP vapor cut valve and EVAP/ORVR line to the EVAP canister. The vapor is absorbed by the EVAP canister and the air is released to the atmosphere. When the refueling has reached the full level of the fuel tank, the refueling EVAP vapor cut valve is closed and refueling is stopped because of auto shut-off. The vapor which was absorbed by the EVAP canister is purged during driving.
2004 Titan CC 4X2 LE Canteen
"SUB out going sinker"
