Old 06-23-2007, 07:36 PM   #1 (permalink)
ProjectTitan007's Avatar
? about 2007' TSB for A/C condenser fan .
I was just wondering if this is something that I can just fix or does the dealer have to do it. From what I've seen it looks like the jumper just crossed the wires from their original position . I think it would be cleaner to just cut the flex cover back and cut and cross the wires back there . Then tape it back up . It would look more stock to me . Is this correct or not . I know my fan comes on it just turns the wrong direction. Maybe BBFanz knows.
2007 Silver Titan CC SE w/ Popular Package.
2006 Suzuki C50 Blue/Gray
Chrome Altezza Tailights, Fog light Kit, SS Gauges, ARE LowPro 2* advance , Magnaflow 12588 and a K&N. Not bad for a start. Oh and an interior that's a bi*ch to keep clean.
ProjectTitan007 is offline   Reply With Quote
Old 06-24-2007, 12:30 PM   #2 (permalink)
Re: ? about 2007' TSB for A/C condenser fan .
Bump Bump..
Old 06-25-2007, 07:31 AM   #3 (permalink)
Come on someone must know in here ...
Old 06-25-2007, 07:51 AM   #4 (permalink)
Clint's Avatar
I'd let the dealer fix it instead of cutting any wires. Should you ever have an issue later you know they would point "the finger" at you. Maybe the miss-wiring is in the fan not the wires. If there was a failure in the future a tech would not get a correct reading with a test meter if your switched them.
Clint
You have two choices in life:
Old 06-25-2007, 08:03 AM   #5 (permalink)
If the jumper just swaps position of the wires then just swap the wires in the connector. It looks like its just a two wire connector. The connector is not that hard to take apart. After you take the lock off of the back, you devise a terminal pick to pick the terminal locks and remove the wires and swap them. Make sure you put the other lock back on the back of the plug. It keeps the wire seals and terminals from backing out. But if it is under warranty let the dealer do it. It might save you from future problems if someone has to go into it and no one remembers anything about it.
cpaul is offline   Reply With Quote
Old 06-25-2007, 09:32 AM   #6 (permalink)
Yah I just got back from the dealer . I stopped to ask about it . They said they don't have the parts in stock yet to fix it. I asked about doing it myself but the TSB says to replace the fan also. Plus they said Nissan wants it on record that it has been done. Thanks to everyone though .
Old 06-25-2007, 02:25 PM   #7 (permalink)
FireWalker42's Avatar
Just had mine done today. First the service writer said to hold on to the TSB and if I had trouble to bring it back in. After the service we were talking about what I had read here and he decided to check the system and I came back as needing it. He said Nissan put out that if the truck has <100 miles to replace the cable but if >100 miles to replace the cable and condenser fan unit. He also said there are two types of fan units, one is narrower than the other and slides out easily and the other requires a little more dismanteling to exchange. FME across the forehead here. Almost two hours but it is done.
2007 Deep Water Blue King Cab SE 4x2
Big Tow Package: Utility Bed
XD spy wheels
Tech12Volt box w/ G1 10's, Sundown 100.2, Boston Pro60, Sundown 100.4, Neo typeM tweets, Boston SX60, DNX7100, Backup camera, XM satellite
BakFlip Tonneau Cover, HID lower and Fogs, LED tails, LED 3rd brake light
NISMO CAI: Stillen SS single side exit Exhaust: Superchips Cortex
Stillen Front Sway Bar: Street Scene Speed Grille upper/lower
FireWalker42 is offline   Reply With Quote
Old 06-25-2007, 02:32 PM   #8 (permalink)
Yah I made an appointment for Wednesday . They told me it would take three hours. I was wondering if I should do the timing advance at the same time . But it'll be like a hundred bucks for them to do it . Maybe I can get it done from someone in my area for a lot cheaper.
Help installing 2007 RF HU From SE into a 2007 XE simsdiesel Titan Visual & Audio Discussion 2 05-14-2007 10:56 AM
Mods for 2007 wilk3215 Titan Performance Modifications 27 05-03-2007 11:33 PM
new 2007 gmc goes down chieflikalotapus War Stories 81 02-06-2007 02:25 PM
2007 Titan HP? Stomper4x4 Titan Performance Modifications 15 12-02-2006 09:57 AM
Condenser fan not working TSB Old Speed Titan Problems & Dealer Service 3 09-26-2006 09:18 PM
