Old 07-11-2007, 09:50 AM   #16 (permalink)
Footloose301's Avatar
Re: BAD mpg ??? why
Originally Posted by master_1011
I don't know anything about a debate (although I'm sure there was one) but putting Nitrogen won't change anything as far as a leak in concerned.
I don't know anything about the debate either and I don't run nitrogen. But I seen a poster on the walls in the tire places here that show the air molecules(sp?) compared to the nitrogen and I guess the nitrogen supposed to be larger which means less air escapes and they guarantee to only have to put air in your tires once a year. But I don't know how true that is, I don't have nitrogen in my tires, I drive a Titan, not a civic
But anywho! I had this same problem with the 2 front tires and all I had to do way tighten the sensors on the valve stems slightly. Try that, maybe you'll get lucky.
2004 KC 4x2 SE
PRG Mini Lift
325/60/18 Nitto Terra Grapplers
JL Audio 1000/1
JL Audio 13W7
Pioneer AVH-P7600DVD
Apline Speakers in 5.1 Dolby Digital /DTS Surround
Footloose301 is offline   Reply With Quote
Old 07-11-2007, 11:04 AM   #17 (permalink)
killcatzforfun's Avatar
Re: BAD mpg ??? why
yeah im gunna take er in today or tomorow... right now my disney trip was cancled so were trying to book a cruise or something instead of sitting at home....
07 TITAN CC,O/R,B/T 4X4 SE MAJESTIC BLUE
mods: fram boost air 2 cai.
8000k H.I.D's for low beams and fogs
killcatzforfun is offline   Reply With Quote
Old 07-11-2007, 11:29 AM   #18 (permalink)
master_1011's Avatar
Re: BAD mpg ??? why
I work on helicopters all day everyday and trust me...I have to refill the stinking tires just as much as you would on a car or truck. And we use nitrogen for it. Nitrogen also expands and contracts with heat/cold, but not to such a degree as regular air.
We also use nitrogen to pre-charge some hydraulic systems. There will be leaks so small we have to use leak-detector (basically soapy water) to find them.
2005 Maroon Titan SE CC 4X2
-Volant CAI, 2* Timing Advance
2003 Flame Red SRT-4. <---FOR SALE...PM if interested!!!
-PTP SST w/exhaust mani, PTP 55mm TB, PTP CV, PTP BOV Spring, Mopar Stage 2 w/toys, AEM CAI, MaxxFab 3" O2, ATP DP w/o Cat, Borla Cat-back, MPX Underdrive Pully
master_1011 is offline   Reply With Quote
Old 07-11-2007, 11:57 AM   #19 (permalink)
Rntmake3's Avatar
Re: BAD mpg ??? why
I had the same issue with my original tires/sensors. Nissan replaced the tires, sensors...and I upgraded to the All-Terrain KO's and have had no probs since.
Rntmake3 is offline   Reply With Quote
Old 07-11-2007, 12:26 PM   #20 (permalink)
cneary812's Avatar
Re: BAD mpg ??? why
well... actually you do... 78% to be precise
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
Roadmaster Active Suspension
future mods - JBA Evol , PRG leveling kit, 2* timing advance, Injen Powerflow, and more
cneary812 is online now   Reply With Quote
Old 07-11-2007, 12:53 PM   #21 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
Re: BAD mpg ??? why
one more thing not mentioned about the front tires... if you corner hard and fast a lot in your beast you will lose tire pressure.
good to know about the o rings in the sensors.
2° | AEM Brute Force | 2" NCD Leveling Kit | PRG Shackles| 20" Konig Coastal Wheels w/ 305/50 R20 Nitto Terra Graplers | Aries Bull bar w/ 2 Hella 500 Driving Lights |Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | BB's Extang Trifecta Lease with option to buy
The Urinator™
DeadRiver is online now   Reply With Quote
Old 07-11-2007, 02:40 PM   #22 (permalink)
Wiscdave's Avatar
Re: BAD mpg ??? why
Somethings wrong, tires should not lose air like that. Get it fixed, get better MPG, be happy.
old ride - 04 XE CC 4x4 traded at 62k
Wiscdave is offline   Reply With Quote
