Old 08-21-2007, 11:12 AM   #1 (permalink)
08 Gross Axle Weight rating
Just wondering what the 2008 Nissan Titan GAWR are for the new 7200 GVWR trucks. It will be on the sticker in the door jamb. Thanks.
Craig
PurdueTitan is offline   Reply With Quote
Old 08-21-2007, 04:06 PM   #2 (permalink)
dc_909's Avatar
Re: 08 Gross Axle Weight rating
6399 Gawr Fr.
4200 Gawr Rr.
2008 Blizzard SE KC
Volant CAI-Magnaflow Catback-2/3 McGaughy's-22" AR 311's w/Kumho 305/45's -BullyDog Premium w/ 2* Advance
next mod up : Detroit TT
dc_909 is online now   Reply With Quote
Old 08-21-2007, 05:20 PM   #3 (permalink)
TitanBlue's Avatar
Originally Posted by dc_909
6399 Gawr Fr.
4200 Gawr Rr.
Interesting numbers, far exceeding what the tires or rims are likely rated on the front. Fr and Rr always exceed GVWR. Nice to have some capacity though!
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Old 08-21-2007, 05:28 PM   #4 (permalink)
I am thinking that he meant 3699 for the front axle, right?
Old 08-21-2007, 06:54 PM   #5 (permalink)
dc_909's Avatar
Indeed I did, sorry about the typo
2008 Blizzard SE KC
Old 08-21-2007, 06:58 PM   #6 (permalink)
TitanBlue's Avatar
That's OK, We gotta dream sometimes! Gotta be able to hold that Diesel someday! lol.
So, it is 3699 GAWR Front and 4200 GAWR Rear. Plenty for me...
Born June 12, 2006
Old 08-23-2007, 01:31 PM   #7 (permalink)
How did the 08 rear axle rating go up by 400# yet the differential and axle shaft remain the same as the previous models? The only change was on the axle houseing and that was in regards to the suspension system.
goldwing is offline   Reply With Quote
Old 08-23-2007, 02:37 PM   #8 (permalink)
I thought the axle got a bit larger (but only from what I read; I have no direct knowledge). It did sound like they fixed a few weak links like the spring shackles. Depending on what was the previous limiting factor, you could get a higher GAWR from just bigger tires, or even higher tire pressure recommendations. Tires that aren't running at the max 44 psi get derated quite a bit, in addition to the 10% margin taken out when P-type tires are used on trucks/suvs.
Curmudgeon is offline   Reply With Quote
Gross Combined Vehicle Weight question bolttitan Titan Towing & Hauling 2 04-28-2007 05:45 PM
weight rating of oem hitch dank78 Titan Towing & Hauling 8 11-26-2006 11:32 AM
Our Payload rating isn't so bad. Mike Up Titan Towing & Hauling 51 05-16-2005 08:22 AM
Anyone know the weight rating for rails? mhwo Titan General Discussion 3 12-16-2004 10:52 PM
