2007, 4x4,SE, Radiant Silver, BigTow, Bed Liner, Utilitrack, Utilitrack Bed Divider, Truxedo roll up, N-Fab Step bars,
6 disc changer/MP3, Capt Chairs. Michelin Cross Terrain, Born on Nov 06FOB tailgate mod, Fog lights, Tailgate open light Mod, hard wire Garmin 7200, Hard wire back up camera Monitor, Wet Okole seat covers
2007 Forest River salem Travel Trailor 27RBLE
I use simple green. After the motor is dry, spray STP Son of a Gun protectant on all hoses and black surfaces. Your engine will look new and it makes easier to clean next time.
2005 Galaxy black XE 4X4 - NCD 2.5" leveling kit - K&N Drop in filter and airbox snorkel "chop off" mod - Goodyear Wrangler tires with Silent Armor
Yup. Simple green on a cold engine. Let it soak and rinse with the hose. Works like a charm.
I agree!
You don't want to use any hi-pressure spray on late model vehs, water can get forced into connectors that normally can keep water out.
I would stay away from steam also. There will be guys who claim they do it (hi-pressure/steam) all the time and no problems, but I work on a fleet of the same vehs and can tell you if you hi-pressure enough vehs, there will be issues...
PRG Performance Kit w/SAW's
Born 9/2004
yeah but... i thought the VK56 is a distributor-less design, so no having to deal with distributor caps and such.
Yes, yes. But that is just 1 item. Still lots of "such" to deal with, really! It's the connectors that can be a real problem months/years later .
And yes, the starter failed by the mud that got washed in to it. Water on a starter or alternator, will usually just drain off without any problem. The starter on our Titans is well hidden, many would never have expected it to be where it is. I was surprised!
I do use Engine Brite and hose my engines off at home (twice a year) and at work on a regular basis. I would not use steam for reasons already given. I do use water with caution. And yes, I messed up on that a few times too! I buy at least a couple cases of Engine Brite every month at work, we have a small fleet of hydrualic powered trucks. Lots of cleaning to do.
Just be careful.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
I used this [Gunk Engine Brite] for years, but it leaves a nasty smell when you drive for about a week, so no more Gunk for me!!!
Once, I used the heavy-duty engine brite (didn't read the "HD" part) and it smelled for 2 weeks! The regular stuff was ok and had only a mild orange scent for a couple of days. I think I'm going to try the Simple Green next.
04 Titan 4x2 SE KC, Smoke, Magnaflow Single Exhaust, 05 Diff Cover, Stillen VKPro, AEM Brute Force w/DRYFLOW, Custom Painted Engine Cover , Sylvania Silverstars, Rhino Bedliner, Nissan Bug Smacker, Sirius Starmate 5 and iPod (AUX), Sony xplod, 2 x 10" JL 0, and a locking gas cap
