ok I haven't driven my truck alot since I did this install but I am definately getting better MPG so far. The only thing that I have noticed is that my RPM gage reads higher than my tach does or so it seams by a few hundred RPMS. do any of you have this issue?
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
Roadmaster Active Suspension
future mods - JBA Evol , PRG leveling kit, 2* timing advance, Injen Powerflow, and more
It pobably won't be real accurate on the first tank. When you fill it up you will have to adjust the amount of gallons used. After the first couple of tanks it will be reading more accurately.
Mine rpm reads the same.
yeah I will do a few tank fulls and then report back.
airbox mod with K&N
You mean i have to do the work for it???? Geesh. LOL
Lucky!!!!! I just ordered mine tonight i cant wait to put it in and see the fuel milage im not getting
Lol...exactly why I'm not getting one. I've always calculated mileage on previous vehicles...until this one.
Ignorance is bliss.
2005 CC 4x4 SE
AKA
TreeHuggingHippieWhore™
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
No, all you have to do is when you fill it up you go to the more menu, the the fillup. It will say you used x amount of fuel, it is not exactly what you used, then you adjust it. Takes about 3 seconds to do.
More menu......as in more gas on the Titans menu?????
regardless.........i ordered it. waiting for arrival. trying to determine mounting position. didnt get the blendmount. dont wanna cut the dash.
grats hope you like it like i do. now that I think about it you could always make a wedge and velcro it to the wedge and the upper part of the windshield to give you a proper viewing angle. No cutting.
airbox mod with K&N
I have a space under my Alpine head unit that looks rather inviting for the scangauge.
that works too but just be careful that you dont look at it too much while you are driving. I think the ideal place for it would be directly above the steering wheel upper windshield area sortof like a HUD. It can register MPH and is very accurate at it.
airbox mod with K&N
Here is where i ended up mounting my unit. LOL. I love the way you can change colors to compliment the other lighting. Boy i sure was surprised to see the MPG. Why does it gradually increase as you go? Seems as though it would start from a higher MPG than it does.
Now that doesnt sound like the response i expected from someone who only uses their mirrors when driving?!?!!?
I hope i wont get to distracted, i mainly wanted it for MPG and trips.
yes I use my mirrors alot when driving, thats what you get when you are used to driving 42' long ladder trucks that the only reason for looking over you shoulder is to see the firefighters in the back.
you can set your trip to a gage in the xgage functions. I set one for tank mpg. The mpg that you see is instant mpgs and are all over the spectrum. Set the trip functions and you will get level readings. The instruction book is ok but the pdf version on the web is much better.
airbox mod with K&N
