Ever since i got my '07 Titan when ever I drive my truck near anyone that has a radar detector they keep telling me that my truck sets it off. The other night I sat in the parking lot with my friend and repeatedly turned my truck on and off and watched his radar go off and on with it. I'm stumped
any one have any ideas?
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
I think you should be very afraid here. Clearly, your are emitting significant RF from the transmitter the aliens left in you after the capturing and anal probing. Put your arse against a large magnet to stop it from working and you should be all set.
In actuality, I am guessing it is the signal from satellite radio or your own radar detector (if you have one).
I had this problem years ago when ever a Mercedes was near me my Escort radar detector would go nuts. I was told that the radar or what ever Mercedes used was compatible with X-band radar. The sonar detectors on your Titan should only be working when you are in reverse. Try turning your back-up sensors off and see if his radar detector stops beeping. If it does your system might need some attention. X-band radar is also used in automatic door openers like at the supermarket. My detector hated to go grocery shopping. Some of the newer detectors have gps lockout so you can eliminate false readings like when you drive by the same place that sets the thing off.
I don't even have the backup sensors and as far as the garage door openers go I don't even have a garage so Iv'e never programmed them but that seems like the most likely culprit to me too. I'll have to do some more reseach on the subject.
I have a new 07 and a radar detector mounted under my rear view mirror and have never had a problem?
