Re: Recall - AC Control
Originally Posted by klassa
I haven't gotten anything... I have an '07.
What problem does this fix? I've found that my system seems to run the AC when it shouldn't... For example, if I turn off the defroster, the AC stays on (even though the light is off). Or, sometimes, if I turn the AC off, the light goes off but the air is, without a doubt, being conditioned.
Is this related?
Not related. The controls on the '08's are completely new. The problem it fixes is, the AC may run excessively, and cause the lines to frost over, which will cause the blower output to be minimized. The 07 uses a different control unit all together. The control unit is located in the dash. It is the part with the knobs, and buttons that you use to control your HVAC system.
Rob
'08 Pro-4X LWB Galaxy Black 4WD
Tow, Utility Bed, Rockford Fosgate
Captains Chairs,
PRG mini lift
Zoomers Cat-back exhaust
Hatchie Bottom Max-4 camo seat covers
Nissan Bug Guard
Chrome Nissan Running Boards
Husky Liners
Nismo CAI
Active Tuning Grounding Kit
Eco-3
5000K HID Low Beams
and
'05 SE KC Galaxy Black
Big Tow,Off-Road, Utility Bed
Rockford Fosgate
Captains Chairs
Nissan Bug Deflector
Husky Liners
PRG Mini Lift, Chrome Tailgate Trim, Billet Grille
Window Tint
Leer 100XQ Shell
Extend-A-Fender Flares w/Factory Mud Flaps
Hatchie Bottom Custom Fit Max-4 Camo Seat Covers
Zoomers Cat-Back Exhaust
NISMO CAI
5000K HID Low Beams/ Silverstar High Beams
Active Tuning Ground Kit
