Old 02-19-2008, 05:38 AM   #1 (permalink)
Rims And Tire Combo
Hi,
I found a great deal on a set of used 20" rims and tires
the tires are 265/50/20
These are off a GMC YUKON.
Will the offset be OK?
Does anybody have an idea if they are going to rub?
I need to know asap! Ebay bid is over on Wednesday.
These are for a 2wd. Which I also plan to lower the rear 2" for a sport look.
let me know davidrode@comcast.net
davidrode is offline   Reply With Quote
Old 02-19-2008, 10:43 AM   #2 (permalink)
MFresh's Avatar
Re: Rims And Tire Combo
You've got a lot of missing info.
1. How wide are the wheels?
2. Bolt pattern?
3. BS/Offset?
MFresh is offline   Reply With Quote
Old 02-19-2008, 12:09 PM   #3 (permalink)
The Bolt Pattern Should Be The Same... You Will Need To Check Back Spacing And Offset. Is Your Truck Stock, Lifted, Or Lowered? You Would Need Hub Centric Rings...
You Definately Need More Info On The Wheels!!
NICK@STILLEN is offline   Reply With Quote
Will this Tire/wheel combo fit? smoke77 Titan Wheels, Tires & Brakes 2 09-24-2007 10:01 PM
Help me decide on a wheel/tire combo DRKSDE Titan Wheels, Tires & Brakes 26 06-26-2007 08:03 PM
what size wheel/tire combo? cardesigner Titan General Discussion 14 01-17-2006 02:36 PM
Wanted: XE wheel & tire combo - MA/NH only Tony Buy/Sell 1 07-29-2004 04:45 PM
