I saw that Red Line D4 ATF is suitable for our trannies. They say its Nissan Matic J compatible. I know that Royal Purple and Amsoil also have ATF we can use. I've read here that a few ppl have been using Amsoil w/out problems. Just wanting to know if any one is using the Red Line Stuff. I'll by changing the diff', tranny, and transfer oil in the next week or two. Just want an opinion
I'm a big fan of the Redline oils...Where did you read that it's compatable with the J-Matic?
PRG Performance Kit w/SAW's
Born 9/2004
Synthetic D4 ATF is suitable for use where Dexron III, Dexron III H, Dexron II, Toyota T-IV, Hyundai, Voith, ZF, Nissan Matic-J, Honda Z-1, Mercon, or Mercon V
fluids are recommended. The D4 ATF is designed with superior low-temperature properties compared to a DexronIII fluid, and the improved shear-stability requirements
which is part of the new Mercon V specifications. The D4 ATF also provides significantly improved gear protection and will provide a GL-4 level of gear protection,
making it a superior product for transmissions and transaxles. The balanced frictional characteristics provides smooth and consistent shifts for extended drain intervals.
The superior stability compared to petroleum ATFs allows high-temperature operation without varnishing valves and clutches which leads to transmission failure.
Nissan service dealers will not tell you it's ok to use this, nor recommend it for warranty reasons. If your truck is out of warranty then give it a tug!!!!!
red line is good stuff i wonder what kind of trans fluid dealerships use when you get your trans flushed.most new cars and trucks run trans fluid that dont spark for electroinc purpose thats just what nissan calls there's is j fluid chevy uses dexron 4 or 5. i had my trans flushed used bg fluid.works fine.
My dealer said I could use any oil as long as its Nissan J Matic compatible. The flush would be $120.00 with my own oil. This sat it goes in to fix my heater. I rather have them do the tranny flush for warranty issues. I'll do the other oils myself.
Oliver
2006 CC 4x4 Radiant Silver: Offroad Package, Tow Package
Current Mods: Glasspack muffler, Helix TB, True Flow Air Filter, Air Box Mod, Airlift Air Bags, 35x12.50x17 Big O XT LT tires, 2º Advance, 2.5" Racerunner Coilovers, Deaver MiniPack, Rear Bilstein Shocks
Wish List:Upgrade Stock Radio
2005 trx400ex: tcs Front Shocks
2001 xr650r: Tag Handlebars w/Bark Busters, Uncorked, Glass Lens Headlight, Precision Concepts Revalve, smartperformanceinc 215/VM2-K5 fork oil.
2000 yz426f: stock
