Old 02-24-2008, 11:01 AM   #1 (permalink)
9-d-9's Avatar
Off-Road Tool Kit - What would you pack?
I am going to be building up a tool kit for when I'm stuck out in the middle of the desert broke down or buried in the sand, I'll at least have a chance of getting out of the situation. So throw out some suggestions... what has got you out of a situation?
9-d-9 is offline   Reply With Quote
Old 02-24-2008, 11:11 AM   #2 (permalink)
yamatitan's Avatar
Re: Off-Road Tool Kit - What would you pack?
hmm a winch, couple of good tow straps, shovel, and hi lift jack.
Old 02-24-2008, 11:35 AM   #3 (permalink)
A.I.I.Raciing's Avatar
The cheapest tools you can find, cause your goona lose them anyways.
Here is what I carry in the trucks:
5-6 sets of Vice grips
1qt of oil
Full socket set(deep set if needed also)
Plyers of all sizes
BFH
Tire Plugs
Fire Extinguisher
Epoxy
Duct tape
Electrical tape
Connectors
Mag light
Fuses
Bail wire
Full set of wrench's
Zip ties
Tire Iron
Zip lock bag full of random nuts and bolts
Light weight Craftsman race jack or something similar(NO Hi Lift Jacks)
32oz bottle of water that I keep for the radiator in engine compartment and a 1 gallon jug for me and co-driver in the cab.
*Fully charged cell phone
A.I.I.Raciing is offline   Reply With Quote
Old 02-24-2008, 11:54 AM   #4 (permalink)
In addition to AII's post I've always found it nice to have a test light/volt meter. and some extra fuses. it also never hurts to have a few butt connectors. hammer, air tank, or a compressor that works off your truck. also a nice Flashlight. You can use a tow strap to pop a tire back on it's bead with the help of some liquid hand soap. I think it also helps to have a few extra wheel studs/lug nuts.
When I used to go out in the Dunes a lot I pretty much prepared myself to do just about anything. I always had some Stop-leak for the radiator and a can of fix a flat just incase i got sand in the bead and couldn't get a good seal.
But then agian I usually took a rig that my old man and I built. so we usually had some sort of small electrical problem, or had to do some on the spot riggin. Hope this helps...
2008 CC SE 4x4 Titan, Majestic Blue, Born: 15MAY07. "Chuck Norris drives a Titan out of fear of it being the only thing on earth that could kick his ***."
CRYPYKev is offline   Reply With Quote
Old 02-24-2008, 11:59 AM   #5 (permalink)
Nice suggestions so far! Be sure to add:
A Chain with hooks (about 6’ long)
Water (drinking and some for the radiator)
Oil
A blanket
Once this thread gets pretty long someone should compile all the best answers and make the end all be all list.
lowlypawn is offline   Reply With Quote
Old 02-24-2008, 12:16 PM   #6 (permalink)
Ah, I almost forgot. I keep everything neatly packed in a Contico Box. Which is a ruggedized plastic tool box which locks. I like it because it keeps everything organized has ample storage space for all of my tools. I believe you can pick em up at your local Sears, or Walmart.. Also some J.B. Weld or other type of quick epoxy, and a box of condoms or latex gloves, to wrap electical parts and provide extra protection when moisture is imminent.
Old 02-24-2008, 06:52 PM   #7 (permalink)
don't forget the duct tape
Quin is offline   Reply With Quote
Old 02-24-2008, 07:14 PM   #8 (permalink)
FaFaFooey's Avatar
Isn't that the truth, a sticky should be in order to help us that aren't sure what to keep handy.
FaFaFooey is offline   Reply With Quote
Old 02-24-2008, 07:22 PM   #9 (permalink)
albonismo's Avatar
a helicopter
'06 Smoke XE CC FFV
Mods: Black Westin Bull Bar, AEM Bruteforce Intake, Stillen Dual Rear Exhaust, ReadyLift 2" Leveling, LE rims, BFG AT KO 305/65r18
Future Mods: Detroit TruTrac, Fender Flares Click here for pictures
Gezuar Pavaresia!
albonismo is offline   Reply With Quote
Old 02-24-2008, 07:33 PM   #10 (permalink)
anmut's Avatar
All off road packs need a helicopter!
What I carry standard in my truck:
- Toolbox full of cheap tools
- Recovery & Tow strap
- Jumper Cables
- (winter only) Blanket
For off road: Everything above &
- Small shovel
- Chainsaw
- 2x4's
Mods: 2* Timing Advance · AEM Brute Force · Burn-out Mod @ ECU · 18" Magnaflow · Nissan OEM Brush Guard · Hellwig Traction Springs · Jason Topper
Wish List: Nerf Bars · LineX Spray-In Bedliner
Waiting For Support On: TruTrac · UpRev
"I can't find anyone to race..."
anmut is offline   Reply With Quote
Old 02-24-2008, 09:31 PM   #11 (permalink)
loufish's Avatar
It's a question of how much stuff you want to keep in the truck...
I have a desert tool box for my bike that works well because after all the trucks metric...The box has a complete set of 1/4" drive sockets, wrenchs 8mm-19mm screwdrivers, 1/2" Craftsman flex head ratchet and socket for the truck wheels, misc pliers, dikes, safety wire & pliers, 12V test light, several shop towels and cottong gloves and no less the 3 different flashlights and extra batteries...The box goes out on riding weekends or when off roading(see attach pic on how it stays put)
My 30ft strap always stays in the truck along with all the flashlights...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 02-25-2008, 09:30 AM   #12 (permalink)
jiggadog's Avatar
this is a great thread. def some great suggestions.
jiggadog is offline   Reply With Quote
Old 02-25-2008, 09:45 AM   #13 (permalink)
9-d-9's Avatar
Good replies, especially the helicopter
-First Aid Kit, Water, A few granola bars
-Can of ether with some matches, to seat a tire bead
Keep 'em coming
Old 02-25-2008, 10:04 AM   #14 (permalink)
joeinstl's Avatar
Tire plug kit with the rasper and snakes. **Every titan owner should carry this stuff, comes in handy in a jam.
Almost forgot, pack a fishing pole and tackle just in case you happen upon a good spot.
2005 SE KC 4X4
"If there must be trouble, let it be in my day, that my children may have peace." - Thomas Paine
joeinstl is offline   Reply With Quote
Old 02-25-2008, 10:37 AM   #15 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
In addition to the above, I always bring some drift pins and brass punches just incase....
2* | AEM Brute Force | 2" NCD Leveling Kit | PRG Shackles| 20" Konig Coastal Wheels w/ 305/50 R20 Nitto Terra Graplers | Aries Bull bar w/ 2 Hella 500 Driving Lights |Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | BB's Extang Trifecta Lease with option to buy
The Urinator™
DeadRiver is offline   Reply With Quote
glass pack bleedingbuddies Titan Performance Modifications 3 05-23-2007 08:04 AM
block and mini pack AETitan Titan Suspension 2 03-12-2007 04:30 PM
Which Deaver's Pack? mnmsmith Titan Suspension 0 07-28-2006 06:44 AM
XE 4WD w/ OFF ROAD PACKAGE or SE 2WD w/ BIG TOW or OFF ROAD PACK crewcab4pd Titan General Discussion 10 06-08-2004 12:55 PM
